Pistol
currently Mission Tx.
I've read a lot about new diesel's not being able to use lo-sulf, er fuel because it is harmful to the motor. What about 90 to 95 diesels which wern't made to use lo-sulfer is the new fuel harmful to these trucks and how does it effect milage and power?
jefff929
Pacific wonderland, wet side
They are supposed to be able to use ULSD with no issues.
What kind of a diesel do you have?
2001 Dodge 2500 QC, Diesel, Auto, 4x4 Shortbox, Stull running boards, 26.5' Sundance 5er
My Baby
Another NWBomber
david_42
Oregon
Your diesel (assuming it is less than 40 years old) was designed to use low-sulfur diesel and will have no problems using Ultra-low sulfur diesel.
Kennedycamper
Algoa, Texas
If your concerned about the lubricity of ULSD put some 2 cycle oil in with your fuel. It's about 8 dollors a gallon at Walmart. Make sure it's the ashless/smokeless stuff. TC-W3 I think. It's in a blue jug.
goodcruisin
Greenwood, IN
This is an unbiased factual study. The only thing I don't like about it is that they used ULSD prior to it receiving it's lubrication package. Most sources state that the lubrication package that producers use meets or exceeds standards. However, I've also read studies that some companies go light on the lubricants to help their bottom line.
John (USN Ret) & Debbie
Tux (APBT/Dalmation)
'96 Monaco Windsor 36' DP 8.3 Cummins
Ready Brake & Demco Excali-bar
'02 F250 V10 w/ Banks Power Pack
'03 Ford Explorer
'04 Volvo S80 AWD
'05 Acura TL
240" Dragster 540 BBC
26' trailer
14' Boat w/9.9 Merc
tvman44
Southwest Louisiana
That is why I always add a little "Marvel Mystery Oil" to every tank of diesel. A little extra lubricity may save the day "pump, injectors, ect."
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
coolbreeze01
Redding, Ca
My 94 CTD ran fine on ULSD, and no additives ever.
Prodigy P3, Blue Ox Sway Pro, 225 75R 15E Maxxis
2007 Komfort 212
the_vfox
Osceola WI
I only put fuel in the tank. The only issue I have had is the Bio Diesel junk in the winter time.
Fox and Angel, fuzz ball cat and crazy Yorkie
Don't call me on the weekend, Im out camping.
2004 Chevy Silverado LS 2500HD 4x4 DA 4dr
2003 Jayco Eagle 263 29'Super Slide
Dell Inspiron 1520/WIFI
Go Blue, US Air Force(retired)25 years
SyN
Oklahoma
Goodcruisin: That was the study that i watched closely for months. Spicer did a great job. Thus the reason for me using SoyPower. After 2 plugged fuel filters and 9 months of use. The soypower has cleaned my fuel system up. Thus slightly quieting down the 7.3L injectors.
For those even interested--> I use 10oz-per 30 gal.
http://www.soyclean.biz/shopping/productsdetail.asp?cat=DFA
2001 F250 CC-7.3L-4x4{281K Miles}
"Donaldson's" SD-AIS Intake w/ZooDad-CCV Reroute-DieselSite Remote Coolant Filter-DieselSite Remote Transmission Filter-4"MBRP T.B Exhaust-Red{ELC}Coolant w/RMI-25-{HotShots Secret}
1991 Jayco Designer Series 32'JayCrane.
