Woodalls Open Roads Forum: Dexter HD Suspension & EZ-Flex Install (long w/ pictures)
 > Dexter HD Suspension & EZ-Flex Install (long w/ pictures)
Page of 33
LAdams
Northern Illinois
Posted: 07/02/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I recently purchased the Dexter HD suspension kit that comes with the new EZ-Flex Idler... I had installed a similar kit on my previous Nomad 27' TT and it worked quite well so I decided to install the newer kit on my 31' Nomad... Below is a picture of the kit I installed...
Now it's worth mentioning here that this type of job isn't exactly for the "faint of heart"... Basically what your going to do is to put your TT on Jack stands and rip off the suspension and install a new one... Your going to need a pretty good assortment of standard mechanics hand tools and an air compressor with a variety of air tools is also very helpful... I would also suggest that you buy the Harbor Freight Ball Joint Tool that you see in this post... It is used for pressing in bronze bearings and serrated bolts and works very well for this application...
You could just use a big hammer and beat things into submission, but pressing the bearings and bolts in is a lot more elegant and easier on the frame and also the installers hands... I also used an air operated impact (gun) wrench, an air operated ratchet wrench, demolition bar, numerous 1/2" drive sockets, 3 pound hammer, grease gun, assorted screwdrivers, vise grips and other hand tools...
Start the project by putting your trailer on jack stands on a good firm surface... I also used my 6 stabilizer jacks attached to the trailer to further aid with stability... Here are some photos of that...
You should also have 2 or 3 hefty jacks, either the bottle type or floor type to aid in the installation... I use a 4 ton floor jack and a 12 ton bottle jack... The 12 ton picks up the TT effortlessly and is small and compact... Here are a few photos of them...
Start by removing the standard OEM idlers and shackles... This is done by removing the lock nuts on the inside of the suspension components and then hammering the bolts out of the hangers... All the bolts on my OEM suspension system were serrated, so using the impact gun to turn them and remove them would have damaged the shackle hangers by reaming out the mounting hole... If I would have done that then the new serrated bolts would have no material to bite in to... Here are a few pictures of the old suspension components...
Here is the rear OEM bolt...
In this photo the springs have been removed from the idler and their plastic bearings have not yet been removed...
Once the old components have been removed, you can begin to install the new ones... When pressing in the new bronze bushings, it is a good idea to use a pilot bolt or installation bolt so that the soft bronze bearing does not distort or bend... Here is a bolt I used for that purpose... Note that I ground off the serrations... This bolt is also used to push out (hammer out) the plastic bearings...
Here are a few typical plastic bearings after about 6000 miles... Some were already showing signs of extreme wear...
Now we can install the bronze bushings in the spring eyes... Apply grease to the inside of the spring eye, the outside of the bronze bearing, and the inside of the bronze bearing as well... Then use the Harbor Freight Ball Joint Tool (HFBJT) to push the bronze bearings into the spring eye as shown below...
Once the bearing is pressed into the spring eye, then we press the serrated greasable bolt into hanger using the HFBJT...
This isn't the spring eye but here we are pressing the idler bolt into the hanger the same way you would do it with the spring hanger...
Once you complete the spring eye ends, then you can install the EZ-Flex Idler... It is installed by holding the idler between the frame hanger, inserting the proper size bolt and using the HFBJT to press the serrated bolt into the hanger... In the picture below the EZ-Flex idler has been hung on the bolt...
In the picture below, the serrated bolt is being pressed into the hanger...
Once you have the EZ-Flex Idler mounted you can install the HD shackles for the front and rear springs... Here are a few photos of that operation... The photo below shows one shackle in place...
The photo below shows the second HD shackle being installed...
And this is what the assembly looks like when completely installed...
Here are a few photos from underneath the trailer looking at the inside view of the suspension components...
And here are a few extra views of the HFBJT in use... This tool was really a life saver... We used a similar tool that my buddy had at his shop when we did the previous trailer and I knew I would need a similar tool to successfully complete the installation of the HD EZ-Flex Kit...
And the finished product with the TT wheels again mounted...
It took me all day yesterday to install the EZ-Flex kit and HD suspension shackles on the curb side of the TT... I spent about 8+ hours on it but it was somewhat a learning experience... Today I installed the street side portion of the kit and I did that in about 4 hours... Not too bad for the first time although I don't plan to do another any time soon...
I haven't done a test ride yet - that will come in about 2 weeks when we attend another rally, but I suspect the HD Suspension shackles and EZ-Flex will be a big improvement just like the last one was, although my last one had a solid idler assembly, not rubber shock mounted like the EZ-Flex...
I'm having some problems getting grease to flow in the spring eye portions of the greasable bolts... I called Dexter Tech support and they suggested I reverse their direction... All the greasable bolt holes should run in a horizontal plane facing either the front of rear of the TT as opposed to pointing either skyward or ground ward... Dexter says the grease will not migrate properly if they are in the up or down position... So I reversed the direction of the leaf spring eye bolts and I still can't get grease into them...
I'm going to run the TT a bit and see if the bronze bearings loosen up to the point where they will take grease readily... I remember my last TT being like this and sometimes I had to jack the frame a bit to relieve pressure on the greasable bolts... We'll see what happens with this issue... There were no problems getting grease into the center idler and shackles...
Les
* This post was last edited 07/03/08 07:56am by LAdams *   View edit history
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
JFordBronco
Ball, LA
Posted: 07/02/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
nice write up
2009 F-250 Crew Cab 4x4(5.4 and 3.73's) - finally something dependable
2008 Jayco Jayflight 28BHS
Me, wife, one little girl and one little boy
all along for the ride.
LAdams
Northern Illinois
Posted: 07/02/08 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks - appreciate the comments
Les
XTENTER
MN
Posted: 07/02/08 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Really a nice job. We had ours done last year and what a difference it made. Thanks for showing yours.
Chris,Charlene,Amanda and Samantha
Maggie (Lab/Huskey mix)
02 Ford F250 SC W/6.8 V10
98 Prowler 21L5B 5'er
Reese 15K
emaav
Oregon
Posted: 07/02/08 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Great job, nice pictures, thank you.
Me (Eli) 1972:
1999 Chevy 3500
1993 Shadow Cruiser 21F21RD
Dixonmatco
Santa Rosa, California
Posted: 07/03/08 12:24am Link  |  Quote  |  Print  |  Notify Moderator
Nice! I am thinking of adding them to my TT also..I already have shocks but the combination of shocks and these would be the ultimate..
BTW, have you thought about adding shocks also?
Each component serves a different purpose, but either is a plus and both is even better..
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
NCHornet1
Mt. Airy, NC.
Posted: 07/03/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Les, very nice write up and photos. Let me know how she rides. Mine has never been a rough ride but I like how strong those shackles look. May consider this on my TT.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
LAdams
Northern Illinois
Posted: 07/03/08 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys... Yeah, I think shocks would be a huge benifit - have always heard positive things regarding shocks... Think I'll investigate that as well for possibly my next project...
Les
BarneyS
S.E. Lower Michigan
Posted: 07/03/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Great write-up and photos Les! My kit is supposed to be delivered today so I will probably be doing the same install this weekend. There is one thing I don't quite understand though. You said:
Not sure what bolt holes you are talking about or what they mean when they said the bolt holes should run in a horizontal plane facing the front or rear of the trailer. How would this affect the flow of grease anyway? I can see the bronze bushings being tight and not allowing grease flow, but can't see how the direction of the bolts would make any difference. Also, what did you mean when you "reversed the direction" and is this a problem with all of the spring bolts?
Barney
Hensley "Arrow" 1400# hitch
Visit our website here
LAdams
Northern Illinois
Posted: 07/03/08 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Each greasable bolt has 1 hole in it... According to Dexter, the hole exit is supposed to be in a horizontal plane rather than a verticle plane... I haven't sat down ad figured out what forces are in play in the axles, bolts, hangers, etc but I guess that this is the ideal position for the greasable bolt to be in so that grease will flow readily thru it and lubricate the balance of the bolt surface...
Les
Page of 33
