Woodalls Open Roads Forum: Dexter HD Suspension & EZ-Flex Install (long w/ pictures)
 > Dexter HD Suspension & EZ-Flex Install (long w/ pictures)
Page of 20
2inAlabama
Huntsville, AL
Posted: 11/18/09 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
RCMAN46,
I have googled chain pocket, but have been unable to find anything related to mounting shock absorbers. Do you have a link where I can find a chain pocket? Or maybe a picture?
Thanks for your help.
Just DH & DW
2007 Toyota Tundra Dbl Cab
2008 Sunset Creek 279RB, Prodigy Brake Control, Equalizer Hitch
JBarca
Dublin, Ohio, USA
Posted: 11/18/09 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Guys
I tried to buy the Monroe shock mount kit. None where available and Shock warehouse had no idea when they would be available. This was now 1 year ago. They said they had a hard time getting the install kits. But I did get 4 Magnum gas shocks from shock warehouse. Still in the box...
Monroe may have fixed there supply chain issues now, I hope so, but if they have not, it may be hard to get a mounting kit. I am making my own mounts. I have covered tanks and as such I can't mount the front axle shock inboard of the frame so I have to create a special thin mount to not have the tire hit the shock dust tube.
Good luck
John
John & Cindy
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we where camping!)
RCMAN46
NorthWest
Posted: 11/19/09 07:59am Link  |  Quote  |  Print  |  Notify Moderator
2inAlabama wrote:
RCMAN46,
The chain pocket I used has nothing to do with mounting shock absorbers. It is an item I found in a local farm ranch supply that worked for my application. See this site for what I am taking about Chain Pocket
Sorry the site I listed calls it a stake pocket. I guess it can also be used for a chain pocket.
2inAlabama
Huntsville, AL
Posted: 11/19/09 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Oh, of course, I know what a stake pocket is having grown up on a farm. Thanks.
ShortyMadlock
MO
Posted: 12/08/09 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
ALKO according to their application guide says that the HGR's should be 29 3/4" apart from each other, does anyone have and idea what effect it would have if the HGR's were 29 7/16".
I'm going to be rebuilding the suspension and without a good foundation (HGR) being located where it "should" be all else is pointless. The trailer has never towed right, eaten lots of tires since day one, had front hanger passenger side rehung as that hanger was 5/8" to far back, first repair facility that aligned the trailer shortly after I bought it modified the axle seat to get around that, that axle lost it's u-bolts last month.
I'm mechanical but not a mathematician or english major.
2003 F250 PSD Crew 4x4
2006 Work N Play 28BR
1998 Yamaha lifted w/mods
Honda 2000ie/Northern 13000kw
Hensley Arrow 14000#
ShortyMadlock
MO
Posted: 12/09/09 06:51am Link  |  Quote  |  Print  |  Notify Moderator
OK, think I found what I need on the Dexter site, http://dexteraxle.com/i/u/1080235/f/6-8K_cat_4-07/4000-6000_lbs.pdf
Right now I don't have a spring length in front of me and with the weather being what it is this O.F.F. won't be sticking his head out the door today.
Ordering the EZ-Flex right now.
JBarca
Dublin, Ohio, USA
Posted: 12/09/09 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Hi Shorty
When you get to rebuilding the alxes and alignment, let me know. May be able to help, I did mine this past spring.
However your first note kind of got me. Do not know what HGR's stands for and could not figure out what you where talking about.
But since you are buying an EZ flex, well you are on leaf springs (not torsion) and that distance was most likely axle to axle spacing.
If you wnat to yak more on axle install, take out a new post as it can get long in itself and send me a PM so I can join in the fun....
Stay warm and hang on... The wind is starting to blow already
John
ShortyMadlock
MO
Posted: 12/09/09 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi John, Will do that when I get all the data in front of me, doing lots of reading on hear as well as Dexter's Service Manual, taken lots of measurements I didn't need and haven't taken some I do need. The "HGR" is a manufactures abbreviation for "Hanger" lol - anyways looking at Dexters site in determining the E-Z Flex I need to order I am going to have to do some "bump clearance" measurements as my equalizer is the one that uses the K71-652-00 tandem kit and according to them it will lower the trailer approx. an inch. I'm sitting by the fire thinking I will be alright but don't want to order it and then find out different.
This is why I think I need to measure clearance, but also showing twisted hanger - that is a 5/64" allen in there.
This is one thing that has me hung up - twisted hanger.
Dexter also gave me lots of closer dimensions with regards to if you measure your spring length they tell you what the HGR/hanger spacing should be for double eye (actually for any spring axle 1, 2, or 3).
JBarca
Dublin, Ohio, USA
Posted: 12/09/09 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Shorty
See this Dexter file http://i.b5z.net/i/u/1080235/f/Instruction_Sheets/059-867-00B.pdf
At the end of that file are actual diminsions of the EZ flex. You can measure your current rigid equalizer bolt spacing and compare to the actual EZ flex.
For reading on messed up axle and tire wear see here. There is also link in there for more trouble shooting prior to the new axle install.
TT axle alignment & install - Detailed (long lot's of pics)
HGR's = hanger...LOL You got me....
Good luck
John
NWElkhunter
Oregon
Posted: 12/28/09 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All,
I haven't posted to the forum before, but I've been lurking around for some time and I've gleaned much knowledge since I found it. Here's something that might be of interest.
If you go to Dexter's webpage and click on the inventory reduction sale tab, you'll find a page to help one determine which E-Z Flex kit to order.
My TT has the equalizer like the one pictured at the bottom. There is a warning to check the bump clearance before ordering the E-Z Flex (which is on sale BTW) as it will lower my TT by one inch. Doesn't sound like much, but I want to make sure the frame won't hit the axle or the tire won't hit the top of the wheelwell.
I've been wanting to install this kit, but I'm glad I spotted this information before I ordered. Hopefully, it will help other members, too!
A Happy New to All!
TV 1996 F250HD 4x4 Powerstroke, 4:10's, MaxBrake controller
TT 2007 Jayco 28RBS, Bulldog 4k Electric Jack, more to come!
Page of 20
