Woodalls Open Roads Forum: fifth wheel that can be pulled by 1/2 ton pickup
Search only in Fifth-Wheels
 > fifth wheel that can be pulled by 1/2 ton pickup
Page of 9
Simmang
sa
Posted: 08/12/08 05:05pm Link  |  Print  |  Notify Moderator
We just bought a new Silverado 4/Dr truck with the 5.8 liter engine, 1/2 ton. Does anyone know of a fifth wheel that this truck could pull? Thanks!
Mandalay Parr
Phoenix, AZ
Posted: 08/12/08 05:17pm Link  |  Print  |  Notify Moderator
I wouldn't. Not enough truck for stability reasons. One ton dually much better.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
McIrish
WC IL
Posted: 08/12/08 05:41pm Link  |  Print  |  Notify Moderator
I'm sure you'll find a smaller 5th wheel that your truck will pull. Just do some google searches to see what's available.
2008 Silverado Z71 crew cab
2009 Sunset Creek 267RL
Equal-i-zer
Champion
Rvndave
Medina, Ohio
Posted: 08/12/08 05:42pm Link  |  Print  |  Notify Moderator
A fiver needs 20-25% of total weight for the tounge weight. I recommend you use the GVWR of the 5er to determine tounge weight. Advertised dry weights, and tounge weights are bogus. Most salespeople will tell you whatever it takes to make the sale. Do your own math. Since you already have the truck fill it with fuel and whatever you have that you might take camping, and have it weighed. Subtract this weight from the GVWR found on the trucks driver door, or door post. Unless you have a negative number, this is the weight you can still add to your truck. Fifth wheel hitches will add around 200 pounds. Don't forget to add people 150 pounds each is normal.
I suspect you can get away with a smaller 5th wheel.
* This post was edited 08/12/08 05:48pm by Rvndave *
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
curt12914
Northern NY State
Posted: 08/12/08 05:57pm Link  |  Print  |  Notify Moderator
Maybe a HDT (Class 7 or Class 8 truck) would be better. That should be enough truck to tow a 5000 lb fifth wheel!!!!! I'm sorry, but a one ton dually isn't needed (and actually looks a ittle ridiculous) to tow a small fifth wheel.
Starting about 4 years ago, the tow ratings of "half-ton" pickups increased drastically and is often higher than some of the older 3/4 ton pickups.
Check the weights of your truck and try to find a fifth wheel that matches it. A couple brands that come to mind are Jayco and Cougar. There are many others, but I just can't think of them. I'm sure others can recommend many other options.
05 Ford F-350 Lariat CC 4X4 PSD DRW Line X Retrax
02 Montana Big Sky 3295 RK (2) Honda EU2000is
When my grown kids were inspecting our new fifth wheel, one asked why we bought a trailer that sleeps 4. My reply was that we couldn't find one that sleeps 2!
john b
anywhere USA!
Posted: 08/12/08 06:08pm Link  |  Print  |  Notify Moderator
Check out the Cruiser by Crossroads line as they were introduced as 1/2 to towables.
I now need to hurry out to get a dually 1 ton as the one I have been using for 5 years a SRW isn't good enough according to Mr Mandalay.
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
Posted: 08/12/08 06:33pm Link  |  Print  |  Notify Moderator
I don't know the particulars of YOUR half ton but that's what you need to consider. Many of the newer Fords and Toyotas are rated for towing a large number of 5th wheels but that doesn't mean just ANY half ton can do it without exceeding their rating. Weigh your truck, loaded for travel including the 5th wheel hitch and subtract that number from your GVWR and you'll know how much PIN weight you can handle and that will likely be your limiting factor. Just remember that brochure PIN weights are always for an empty trailer and nobody ever tows around an empty trailer. Use 25% of the GVWR to be safe, as the PIN weight. Good luck / Skip
Ductape
On the Road
Posted: 08/12/08 06:37pm Link  |  Print  |  Notify Moderator
Welcome to the forum!
First check your manual for tow ratings. BTW there is no 5.8 liter. GM has a 4.8 or a 5.3.
Take those tow ratings with a grain of salt. They're published with reference to base model trucks, no options. Real world will be less.
Now put your truck on a scale, with the same contents you would travel with. Compare your scale numbers to the manual and you'll have the truth.
a. GCVWR from manual - total scale weight = max trailer weight.
b. RAWR from door sticker - scale rear axle = max weight fifth wheel hitch and pin weight.
c. GVWR from door sticker - total scale weight = max weight fifth wheel hitch and pin weight.
b & c are alternate methods to get to the same place, and technically you should use both methods and settle for the lower number.
There are some light fivers out there. Good luck!
TV: 2011 Ram 3500 6.7, 2010 Nissan Pathfinder 4.0, 2002 Jeep GC 4.7. Connected via Equal-i-zer to:
Surveyor SV-234, powered by twin Honda 2k.
Toys: Polaris Ranger 800, Tracker Grizzly 1548, Suzuki DR-Z400S, BMW R1200GSA
bigeking
Arlington, Texas
Posted: 08/12/08 06:59pm Link  |  Print  |  Notify Moderator
Jayco, Heartland, Nu-Wa, and Teton is coming out with one. Crossroads is another---watch your weights as mentioned above. I am sure there are others, check company web sites for more, Good luck.
Everett & Jayne
2008 GMC Duramax-Allison Extended Cab Dually Locking 3:73 rear end
Line-x bedliner Pullrite hitch Retrax Bed Cover---2008 Nu Wa DA 339RSB
Life is'nt about how you survived the storm...
It's about how you dance in the rain!
pulsar
Lewisville, NC
Posted: 08/12/08 07:15pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
2008 Journey 37H
2006 CR-V toad
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Page of 9
