dbkennel
Puget Sound WA
Ok, I have been reading about all the cold weather prep some of you guys have been doing, and it got me thinking...
I recently acquried a 2007 Adventurer 810ws, and I was wondering if any of you know of the weak spots for freezing up. I got it in Mid December, and even though we have been using it, I put the pink stuff in.
Mine does have the 1 small duct that disappears into the basement. I have not had time to check out temps etc. But just looking at it it looks like the sewer is at risk right were the dump handles are so I have been afraid to really use all the systems in freezing weather... (just using toilet with 1 gal of pink stuff in it...)
2002 Chevy 2500HD 4X4, 9200# GVWR, 6.0L, Auto, 4.10 axle
2007 Adventurere 810ws
campalaska
Alaska
YAAA another 810ws owner, i think there's 4 here now??? anyway i haven't used mine in winter yet, but it seams pretty good. i will mod it before i use it for winter.
- 1999 GMC Sierra 2500 Extended Cab 6.5FT Bed
- Firestone Ride-Rite Airbags.
- 1999 Adventurer 810ws
dbkennel
Puget Sound WA
Thanks for the reply. At least I won't be using it in as cold temps as you up there in AK!
We have used it a total of 5 nights so far. It has been unseasonably cold here lately... I did wake up one night, and it was 3F deg out. We were toasty warm, but it would have been nice to wake up to a quick shower.
btggraphix
Golden, CO
My suggestion would be to get one of the thermometer setups that have wireless remotes. Or even just stash a few regular thermometers and do some measuring in the most risky spots. You may be pleasantly surprised about how it works.....if may be fine. You can do this without putting water in the tanks....just leave the heater on while parked at home, plugged in, and compare the temps (and make sure to measure outside as well) and see how it does. Or you can just use it and see if you run into any trouble Remember, even those risky spots like the dump bay only need to be 32.1 degrees to not be an issue.
U.F.O.
Sundridge On Canada
I have a 2003 model, have used it to -20c We used all our water and black and grey tanks with no freeze ups The only mod is 1.5 inch blue foam board on the bottom. That duct goes to the basement near the valvesunder the bathroom. But you have to keep the furnace up to keep enough heat down there or you valves will freeze.
[b]U.F.O.[/b][blue]
flaxi
Germany
yes, we do wintercamping with our 810WS/2004. The lowest temps were 0 Fahrenheit. We dont fill the tanks, neither fresh nor black or grey. We put a bucket under the outflow and a jerry can of fresh water inside. So , we don't wory about frozen valves etc.
Crtitcal points are the zones at the walls in the cabinet and behind the cushions. At ALL walls I installed a couple of nice "heating foiles" (AC), which only are comsumpting 120W in total, all together. Thats a perfect system: http://www.heizfilm.de/heizfilme.php .
Now here are 5 810WS owners, aren't we ?! :-)
Dodge CTD 2500/03 & Adventurer 810WS/04
GERMANY
billtex
RI
Yes-5!
Welcome...pics please!
Bill
2006 D/A CC
25'Airstream Excella
Adventurer 810WS
Camping all around New England
Good People Drink Good Beer-Hunter S Thompson
Driver only carries $50....worth of ammo.
campalaska
Alaska
what a good round #. share all your mods you all, love to see em, ill be advertising (bragging) of all my mods/ add-ons this spring/summer. got it all planed out!
Beddows
Abbotsford, Canada
My 2001 Adventurer was not a cold weather camper. Regardless, no matter how well insulated it is using pink stuff is a good idea.
46 Woodie
Elfin Forest, CA 92029
flaxi wrote: yes, we do wintercamping with our 810WS/2004. The lowest temps were 0 Fahrenheit. We dont fill the tanks, neither fresh nor black or grey. We put a bucket under the outflow and a jerry can of fresh water inside. So , we don't wory about frozen valves etc.
I looked on the net for heizfilm and found numerous european sources. Does anyone know a good US source and their experiences with this product?
2005 Ford F350 Lariat crew cab SRW 6.0 4WD,Donahue suspension, air bags, bump stops, tow beast, Toyo AT's
1999 Lance 9500 11'3", Trimetric with dual 12 volts
2003 Interstate 6x12 enclosed trailer
2007 KTM 525EXC
1946 CJ 2A
