Woodalls Open Roads Forum: Technology Corner: MS Word help, how to remove "returns"
 > MS Word help, how to remove "returns"
Frankjake
Beautiful Southern Oregon
Posted: 03/05/09 12:23pm Link  |  Print  |  Notify Moderator
I have a list of severl hundreds of itmes listed (several pages). Whoever created this list, double spaced each item by hitting the return key twice, not by using the paragraph format. I want to remove the "return" in between each item, so it will be single spaced.
I know I can just go throught the put the curson at the blank line and hit delete, then arrow down and hit delete again... and continue. But is there a way to removed these extra spaces/returns?
Example:
Item one
Item two
Item three
Above is how is is now, by hitting return twice after each line is typed. (not by using format paragraph)
But I want it to look like this:
Item one
Item two
Item three
abskws
Pamplin, Virginia
Posted: 03/05/09 02:09pm Link  |  Print  |  Notify Moderator
I think that you can highlight the entire document then right click and click on paragraph. On Spacing make it 0 point on before and auto on after (you'll see at the bottom. Make the line spacing single and check the box that says don't add space between paragraphs of the same style. Hope it works!
allen
Burp
St. George's Island, MD
Posted: 03/05/09 02:17pm Link  |  Print  |  Notify Moderator
I think you can fix this with Replace. In the from field put "^p^p" and the to would be "^p" (without the quotes). The do a replace all. See if that works.
pulsar
Lewisville, NC
Posted: 03/05/09 02:19pm Link  |  Print  |  Notify Moderator
Here is how I do it, using Word 2000.
Select Replace form the Edit menu.
Click on the More button.
Click in the Find what: field.
Click on the Special button and select Paragraph Mark.
Click on the Special button and select Paragraph Mark a second time.
Click in the Replace with: field.
Click on the Replace all button - not visible in this picture, it is behind the Special pop-up menu.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Burp
Posted: 03/05/09 02:22pm Link  |  Print  |  Notify Moderator
pulsar, that is a better explanation. I was too lazy to do the 8X10 glossy.
pulsar
Lewisville, NC
Posted: 03/05/09 02:30pm Link  |  Print  |  Notify Moderator
But you beat me by two minutes. Takes time to develop pictures.
Tom
weasel4
Alberta
Posted: 03/05/09 08:26pm Link  |  Print  |  Notify Moderator
Frankjake
Can't you just highlight the text, go to line spacing in the formatting tool bar and set it there?
BTC
Eagles may soar, but weasels don't get sucked into jet engines.
Frankjake
Posted: 03/05/09 09:12pm Link  |  Print  |  Notify Moderator
absksw, I couldn't get that to work, but I have Word 2000 and I couldn't see that last box to check.
Pulsar and Burp, both your ideas were basically the same, just going about it a little differently. It worked!
Thank you very much to all of you for your help.
wittmeba
Roanoke, Va
Posted: 03/06/09 01:00pm Link  |  Print  |  Notify Moderator
I would cut and paste into Notepad. Remove all line feeds/returns and turn off word wrap.
Then cut and paste back in to word.
To my loving wife, Carolyn:
"I dont love you because I need you. I need you because I love you".
Truck Trailer Scale Calculator Applet
RV MFgs
Brake Controllers
RV Links
pulsar
Lewisville, NC
Posted: 03/06/09 03:35pm Link  |  Print  |  Notify Moderator
How is this more effiecient than using Word's Replace function as described earlier in the thread?
Tom
