Woodalls Open Roads Forum: Fifth-Wheels: DeWinterize my Augusta
Search only in Fifth-Wheels
 > DeWinterize my Augusta
cwobosn
LONG ISLAND NY
Posted: 03/24/09 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have a step by step cheat sheet on de-winterizing and winterizing? I had TTs but this is a little different and I do not want to miss a step.
I have the double door SS ref. but I cannot find the shut off valve but I do have a call into Heartland. Dometic was not much help. Appparently my product on the fridge door is not correct and the ser # on my warranty doesn't match.
I want to get everything up and runnung before I pull out.
Artie & Karen
2008 F-350 Lariat, diesel, cc, drw.
2010 Landmark Augusta
jbeletti
Chicago (Streamwood), IL USA
Posted: 03/24/09 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Artie and Karen,
I will give you some quick advice on de-winterizing so you can get it done and take your first trip.
For more details on this, visit the Heartland Owners Forum. Same for winterizing. Also, open the off-door-side storage door at the UDC and look for a sticker stuck to the inside of that door on the process.
Some basics to de-winterizing your Augusta:
1. Outside at the UDC, flip the Winterize valve to Normal. DO NOT move the Water Heater Bypass Valve yet.
2. Add water to your fresh water tank, turn on the water pump
3. Connect city water to the City Water connection in the UDC - DO NOT turn the water on yet
4. Go inside the RV and run every cold water tap until all the anti-freeze (usually pink) is clear of the lines.
5. Do the same for the shower, the toilet, the washer/dryer connections and the outside shower. Ice maker is trickier so I will not detail here
6. Turn water pump OFF
7. Turn water ON for City Water connection
8. Repeat steps 3 & 4
9. Back outside in the UDC, rotate the Water Heater Bypass valve to Normal
10. Repeat steps 3 & 4 but for the hot water taps
11. Turn water OFF for City Water connection
Done
For the Ice Maker - either deal with several rounds of pink ice cubes or, force the ice maker to into several ice harvest cycles. The process is in the Dometic manual for the refer
* This post was edited 03/27/09 10:44pm by jbeletti *
Jim & Nancy (Ruby & Emme)
2011 Heartland Landmark Grand Canyon
2007 Ford F550 / Chariot 7 Door Hauler Bed
Visit our Blog
