Woodalls Open Roads Forum: Honda 2000i Carb Job With Photos Must Read!!!!!
 > Honda 2000i Carb Job With Photos Must Read!!!!!
Page of 11
scootsk
Long Island, NY
Posted: 12/31/11 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Next time it happens perhaps I will. Daylight savings time is over, had to finish the project before dark.
Don, Kathleen and our little men Henry, Will and Bailey the Wonder Wheaten
02' Chevy Silverado 3500 Crew Cab 4x4 Dually 8.1/Allison (The Gasoholic)
2010 Jayco 351 RLSA Fifth Wheel
Reddog1
El Dorado, CA
Posted: 12/31/11 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have never heard of the Honda 2000 having a valve issue before. Do you have any idea as to the cause?
Personally, my only problem has been from pouring water in the Honda from my fuel cans (condensation). Over the past six years, I have done this several times. I just dump the tank, refill and good to go.
Bigfootford pointed out my Honda was running a bit rough, and I have noticed it is one or two pulls of the rope harder to start. Maybe it is time I gave the Carb a little TLC.
Wayne
coolbreeze01
Redding, Ca
Posted: 04/09/12 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Two years ago, I drained the gas and put my 2000i in its box. Today I put some gas in it, applied the choke, and in about 5 pulls it started and ran just fine. Good equipment
Prodigy P3, Blue Ox Sway Pro, 225 75R 15E Maxxis
2007 Komfort 212
DLW
Johnson City TN 37604
Posted: 05/01/12 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
For the record, my 2000I got difficult to start, then started surging on eco thottle. I didn't feel good about cleaning it myself so I took it to local authorized shop - quoted $85, two weeks later after the trip without it, picked it up - bill $185. Ran ragged - two months later now surging on eco and normal. Never again - letter to Honda to follow!
Gonna run the seafoam first after cleaning up fuel, then she comes apart on my bench if not better.
Want it done right - well you know!!
Great little machine but one really must watch the clean/stale fuel issue.
Thanks for great post !
Gean. Larry & Roxie
Chevy 3500 4WD/HD/DW Crew DuraMax Allison B&W Hitch
AVION 37 - W4AUE 146.52
Wrkn2mch
New River, AZ
Posted: 05/02/12 12:30am Link  |  Quote  |  Print  |  Notify Moderator
Best tip i can give you is to run it once a month for 1/2 hour (every month without fail), eco-off and under a 1500 watt load like a small ceramic heater on high. this will keep the fuel in the bottom of the bowl moving so that sediment doesn't collect there.Some Sta-Bil or seafoam in the fuel is good too if you don't use it much and the fuel will be in it for a while.
Joe
birdsong10us
Fort Myers, Fl
Posted: 05/18/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Have been eagerly reading all that I could about servicing this Gen. Mine is 7 years old and has never been serviced! It has always started first pull so it was a surprise when it grumbled and died! Cleaned the carb (however didn't get into the jet part as S.O. said it wasn't gunked up!) replaced fuel, and spark plug. Have spark but sounds like its starved for fuel. Once got it to run for a moment but only weakly.
Should I look at the fuel filter? Have to add that it has run @ 1/2 throttle for years...only recently did it start to surge sometimes. Must add...I'm female and motors aren't my thing but I'm willing to learn! My little genny goes horse camping with me and powers all of my electric yard tools! We are companions!!
birdsong10us
Fort Myers, Fl
Posted: 05/18/12 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah...Taking a bow! My FIRST carburetor job!!! Wouldn't start after working on it for most of the day...I think I have pulled that cord well over a 100 times...taking apart the case was like a cartoon in itself. Thankfully found the video that showed the two long screws from the rear. DUH sigh..difficult when you are working with someone with "all the answers"....anyway...Cleaned the fuel filter also but wouldn't start. At dark thirty with one last attempt I insisted on removing the carb and following ALL of the directions with cleaning out the jet too. Doing the happy Dance!!!! Started with the very first pull. Oh yes, found some trash in the bowl that my SO didn't want to remove and clean also earlier.
You guys are the greatest! My genny and I are happy!!!
By the way...I am a 60 year old woman that has never done anything like this before...proves all you have to do is try! )
jimintomah
Tomah, WI 54660
Posted: 05/18/12 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
birdsong10us,
Nice job, I'm going to show this to my wife for inspiration. I did the carb job back in August of 2010 according to the guide posted by AISURFFISH in the beginning of this thread. It's has worked prefectly. I went so far as to print the instructions and put it with my owners manual, I'm sure I will be doing it again.
Jim
Jim & Kathy & The Dogs
2011 Itasca Cambria 30C
birdsong10us
Fort Myers, Fl
Posted: 05/18/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you, thank you...(still feeling a bit proud) It was really all very simple now that I look back at it.
Those instructions were amazing and how thankful I am to those people that take time to help others.
I telephoned the local repair center and was told minimum of 3-4 weeks and many $$$$.....HaHaHa!!!!I feel good!
Page of 11
