Woodalls Open Roads Forum: Truck Campers: Replacement Shroud for Duo Therm AC unit
Search only in Truck Campers
 > Replacement Shroud for Duo Therm AC unit
DMas
Long Island, NY
Posted: 05/31/09 07:23pm Link  |  Print  |  Notify Moderator
Was up on the roof of the TC doing some spring cleaning and noticed the rear corner of the AC shroud is smashed. Not sure how it happened - maybe a branch fell on it over the winter? Anyway, I'd like to replace it but I'm not sure how to go about getting a replacement shroud.
TC is a 2003 Lance 1161, AC unit is a Dometic Duo-Therm 59530.532. From what I can find, the 595 series was called the "Quick Cool", but I can only find references to replacement shrouds for "Brisk Air" or "Penguin" series replacement shrouds. Anyone ever replaced a Duo-Therm shroud? Is the "Quick Cool" the same shroud as the "Brisk Air"?
Thanks in Advance.
Dave
2003 Lance 1161
2013 GMC 3500
USAFBILL
Alabama
Posted: 05/31/09 07:29pm Link  |  Print  |  Notify Moderator
Several sources including Camping World or just a bit of duct tape. They run around $100.00.
Crazy Ray
Monroe,La
Posted: 05/31/09 07:49pm Link  |  Print  |  Notify Moderator
www.icontechitd.com
click on rv shrouds
RET ARMY 1980,DW Donna,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4SAMS 6V,all LEDS 525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
DIMDave
Sachse, TX
Posted: 06/01/09 08:54am Link  |  Print  |  Notify Moderator
I got one through eBay from Bill's RV Appliance in Elkhart. ~$70 shipped.
The main shroud is 10" tall, the gray rivet-on skirt adds 2".
97 Sun-Lite Eagle RK
01 F250 CC SWB PSD
jauguston
Bellingham, WA
Posted: 06/01/09 07:56am Link  |  Print  |  Notify Moderator
There is a good chance if you go to a good size RV repair shop they will have several Brisk-Air's piled up out back. When they fail they get replaced. I needed one to do a hybrid conversion to put a 6000btu window AC unit guts in a Brisk-Air housing and the local shop had four stacked up in back. They gave one to me. I now have a roof AC that runs fine powered by my Honda EU 1000i (-:
Jim
350hp Cat C-7 w/MP-8
Pressure Pro TPMS
bb_94401
Columbia Falls. MT
Posted: 05/31/09 11:16pm Link  |  Print  |  Notify Moderator
DMas wrote:
AC unit is a Dometic Duo-Therm 59530.532 .... Is the "Quick Cool" the same shroud as the "Brisk Air"?
Thanks in Advance.
Dave
According to this RV Parts Superstore website, the 59530.532 is a Brisk air model. Went to their index, then under Category selected "Air Conditioning", then "Duo-Therm AC - Brisk Air Model", then scrolled down to "590530532", then under "Shrouds & Main Components" on the second page it shows both a 10" and 12" version of the shroud, with a picture of the 12" one.
Does yours look like this?
Also the link to IconTech should be www.icontechltd.com
This is a direct link to the A/C Shrouds.
'05 Ram 3500, 4x4, DRW, LB, 6spd man, CTD, PRXB exhaust brake, Roadmaster bar
'01 Corsair 10'8" - 4,200 lbs., Xantrex XADC 80A, Link 20, 4-Lifeline GPL-4CT, PowerGate Isolater, 2 AWG wire, PI 30A EMS, 2 Honda EU2000i, parallel kit, ext. duration tank.
