Woodalls Open Roads Forum: Travel Trailers: Adding digital thermostat?
 > Adding digital thermostat?
Page of 6
LeBout
Eastern Oregon
Posted: 08/09/09 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I'm not at all impressed with the thermostat in my 2006 KZ JAG TT. It allows the trailer to get too cold before coming on, and stays on long past where I have it set.
Is it possible for me to add a digital thermostat, and if so, what should I be looking for?
Thanks!
2006 K-Z JAG 25JQ bunkhouse model with rear slide
2005 Ford F150 Supercrew 4x4, 5.4L Triton V8
Prodigy Brake Controller
Eastern Oregon, USA
Check out our 2006 JAG here
pete42
Ohio
Posted: 08/09/09 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Not only is it posible it has been done many times.
do a search and you will find the one to buy and how to install.
seems to be a great upgrade.
I think they used a hunter from wal-mart but do the search.
robbie69
wauconda, il usa
Posted: 08/09/09 08:18am Link  |  Quote  |  Print  |  Notify Moderator
check with LAdams(modertor here)
i did it and am very happy with the results-a lot more constant temp weather heating or cooling
on looking quickly-try here
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
LeBout
Eastern Oregon
Posted: 08/09/09 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info. How many trailers use the same thermostat to control both AC and heat? Mine controls the heater only. AC is ducted but controlled directly on the overhead unit only.
tvman44
Southwest Louisiana
Posted: 08/09/09 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Got mine at WallyWorld for About $25 or $30.00, very good mod that you will enjoy.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
robbie69
wauconda, il usa
Posted: 08/09/09 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Les,
here are some updated pics of the newer version of the hunter thermometer
downtheroad
Puget Sound
Posted: 08/09/09 09:10am Link  |  Quote  |  Print  |  Notify Moderator
It's a great mod - fun and easy to do.
Here is ours. The red button is how I control the high-low fan speed.
GMC Duramax/Allison (LBZ)
Komfort 277TS .... Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
shadows4
Kansas City, Mo
Posted: 08/09/09 10:11am Link  |  Quote  |  Print  |  Notify Moderator
This is a great mod and easy to do. After having mine for the last year and a half the only thing I would do different is forget about the hi-low switch. I have mine on hi and haven't changed it yet. As to the OP, not sure how you would hook up to your AC. Maybe someone with more knowledge will chime in. John
2000 4X4 Excursion Limited 6.8V10, 4.30, 129,000 miles
Hellwig Rear Sway Bar
Roadmaster Active Suspension
2000 Coachmen 297 RKS (Approx. 9000lbs loaded)
Reese Dual Cam Sway Control
I WORK FOR FORD, I DRIVE A FORD!
old guy
Oregon (pronounced Or e gun)
Posted: 08/09/09 11:00am Link  |  Quote  |  Print  |  Notify Moderator
it's so easy even I did it. I went to wally world and bought a hunter unit and with the help of others on the forum., I wired it right the first time and it even works. You just have to remember to keep fresh batteries close by. I turn mine off during the non use months and the batteries have lasted about three years now. come to think of it, maybe it's time for me to put in new ones.
robbie69
wauconda, il usa
Posted: 08/09/09 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Buckey-here ya go
from the wall i have 6 wires-brown, white, yellow, green, red, and blue.
they are connected as follows, TT wire 1st and hunter connection 2nd
brown to "G"
white to "W"
yellow to "Y"
green to "Rc"
red not used
blue to #2(of 3) post of fan switch(disreguard if not using hi/lo switch)
jumper from #1 post on fan switch to "G" (see above)
and "Rh" and "Rc" jumped-beleive theromostat comes pre jumped
here's the switch-forget the part number but it's the one LAdams suggests
note: keep in mind that the red wire in the photo is the blue TT wire
Page of 6
