Noel
Southern Oregon
Found a dripping coolant hose leak yesterday. GM 8.1 L gas engine on our 2004 Sightseer P32 chassis. Small diameter 1/2 or 3/4 ???
Am thinking it would be a good time to replace all the hoses. And get new clamps (maybe stainless steel). This are original hoses.
MH at a repair shop now. Whadda you think?
BTW, I tried to find a complete hose replacement kit for the 8.1 L. No luck. Can someone post a live link?
Thank you
Noel
2004 WI Sightseer 27C
Kajtek1
CA
Most of the house hoses in my 1972 conversion are original. I replaced radiator hoses 3 years ago when I recored the radiator. Didn't have any problem with hoses, but figured out that I got my money worth.
Bought big size hoses at Fleet Pride. 3/4 " heater hose was available at local hardware story.
BIKERK9
Santa Cruz, CA
When one goes bad, others will surely follow. Replacing all of the hoses at one
time saves time in the future. Heat is a killer of rubber. Check all rubber hoses
including power steering, wiper hoses, and rubber brake lines.
DoggyDaddy
2008 Damon Outlaw 37', WH-24, 8.1 GMC
Class A Toy Hauler
DoggyDaddy CommunityProfile
Daveinet
il
I think something is wrong. While heat hurts the rubber, there is no way that you should be having problems with failing hoses. 10 to 15 years should be much more typical. Unless you have some poor grade hoses, but something isn't right.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/Edelbrock MPFI,Thorley's & Magnaflows,
KoniFSD,Class A built for gear heads
My Revcon
Revconeers Forum
If spending too much money got us into this mess, why is spending more money going to get us out.
wny_pat
Western NYS
Agree with Daveinet. But bet that shop you are at would love to have you do it!!!
Rick Jay
Greater Springfield area, MA
I agree that it seems too soon to have to replace those hoses. Are you sure it was a leaking hose? The 8.1 liter had a problem with a weeping freeze plug? (Somebody help me out, I forgot what was actually leaking. I remember tightening mine, and it was on the driver side of the engine, a pretty common problem from what I remember.)
It could be the hose clamps just needed to be tightened or maybe one broke. Did the hose actually burst?
~Rick
2005 Georgie Boy 3625 DS on a Workhorse W-22 (Class A)
Rick, Gail, 1 girl (13-Angel, Lexi96.org), 1 girl (8), 2 boys (9 & 6).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
dunnpe
Antioch Ca
Noel, go to this web site http://www.oemys-performance.com
You will see he has cross references for all 8.1 coolant hoses etc. He has lots of cross reference numbers for numerus 8.1 Vortec parts. I have used serveral. His web site is amazing. Hope this helps.
Pete
2003 Itasca Suncruiser 33V
1996 Ford Ranger Toad
KOG
Winterville GA
I'd replace all of the hoses, belts, plug wires, brake fluid, coolant and thermostat after 5 years, but then I'm not fond of being towed in off of the interstate.
Noel
Southern Oregon
Thank you for all the prompt responses.
The problem was not a hose but a leaking "heater valve" connected to a 3/4 inch or so hose, high up on the passenger side.
I did have brake fluid changed out few weeks ago and last year had power steering, transmission fluids changed as well as coolant. Belt is three years old.
