Woodalls Open Roads Forum: how to replace a propane tank with a larger one on a Class C
 > how to replace a propane tank with a larger one on a Class C
pianotuna
Regina, SK, Canada
Posted: 10/29/09 03:59pm Link  |  Print  |  Notify Moderator
I do adore my new RV--but I surely miss my old much larger propane tank. Assuming there is enough room, physically what would be needed to increase the capacity on the tank?
I used to boondock for the whole winter on one tank of propane--and in the new RV one "not too cold" night took over 1/4 tank! (And that was with one 1500 watt electric heater running full tilt!
Regards, Don
enblethen
Moses Lake, WA
Posted: 10/29/09 04:06pm Link  |  Print  |  Notify Moderator
You may need to replace the low pressure line from the regulator to the rigs main LP line.
Check the brackets on the frame to insure they will fit new tank.
You may check to see if rig had an optional larger tank and get info from manufactuer.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
2003 Chev Ice Road Tracker
Polishnurse
Schodack, NY
Posted: 10/29/09 04:14pm Link  |  Print  |  Notify Moderator
You might want to consider and Extend A Stay.
PapPappy
Wilmington, NC
Posted: 10/29/09 04:34pm Link  |  Print  |  Notify Moderator
That Extend A Stay would seem to make a lot more sense! There are so many variables involved in replacing a tank....with the size restrictions being number one! You would also be adding weight to the RV, reducing your payload.
If you plan to make trips long enough that you need to go that much larger, I'm wondering why? Seems like you are using quite a bit of LP in your RV.....a quarter tank in a night? You might want to have it checked out for a leak or something......
I'll also assume that you knew that the tank wasn't FULL when it was filled. so if it's down to "3/4 full", you hardly used any LP.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau ">
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.">
Purchased April 2008"> FMCA# F407293
The Pets
GlennH
Highlands Ranch, CO
Posted: 10/29/09 05:02pm Link  |  Print  |  Notify Moderator
enblethen wrote:
Where is the OP going to carry a large full bottle to utilize an Extend-a-Stay?
I keep mine in the back storage bay.
Our 2002 Four Winds Motorhome
enblethen
Moses Lake, WA
Posted: 10/29/09 04:59pm Link  |  Print  |  Notify Moderator
pulsar
Lewisville, NC
Posted: 10/29/09 05:05pm Link  |  Print  |  Notify Moderator
Moved from Technology Corner to Tech Issues.
pianotuna
Regina, SK, Canada
Posted: 10/29/09 05:42pm Link  |  Print  |  Notify Moderator
Hi PapPappy,
I use my RV at -37. That means *lots* of propane use.
My new RV has a larger "foot print" (i.e. bigger in all three dimensions) than my old one.
Unfortunately I know the propane tank was full--or at least that is what the gauge said. It's just too small for my needs. The web site suggests it is a 60 pound tank--but it looks pretty darn tiny. It was just -6 C on the night where I used 1/4 tank.
Is the "real" size stamped anywhere on the tank?
The Texan
Cascade, ID - Wellton, AZ - Toquerville, UT
Posted: 10/29/09 05:43pm Link  |  Print  |  Notify Moderator
Most LP companies rent them for the season.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/ 2016 Rzr 900 & 2013 Rzr 570 riding in 24' trailer in back.
Where the wheels are stopped today
T_Bone
Arizona
Posted: 10/29/09 07:19pm Link  |  Print  |  Notify Moderator
Hi Don,
As long as the new tank is DOT certified, or in your case CGA, then your good too go, if'n you have room. Most tanks will pass both USA and Canada codes but the new tank also has to meet DOT rules since it's a "fixed" tank, meaning not removable, for road use.
[emoticon]
T_Bone
02 F350, 4x6, CC, DRW, PSD, 6spd, 3:73
32ft Serria 10yr 100% Solar
Please do not trust everything you read on the internet. Use only valid engineering information from well established Companys.
Buy UNION Work UNION
It pays off in the long run !
