Woodalls Open Roads Forum: Will the 1200lb Equalizer be okay with this camper?
 > Will the 1200lb Equalizer be okay with this camper?
crispyc21
VA
Posted: 11/04/09 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Here's the story...
I was originally going to get a camper with a dry tongue weight of 800lbs. (dry weight of camper 6085lbs). Figuring the loaded tongue weight would be closer to 1000lbs. I purchased an Equalizer Hitch with the 1200lbs weight bars.
The deal on that camper fell through. The new camper I am getting has a tongue weight of 590lbs (dry weight of camper 6108lbs). I'm sure the loaded tongue weight will be around 800lbs or so.
Will I still be okay with the 1200lbs bars or should I get the 1000lbs bars?
another_newfie
Ontario
Posted: 11/04/09 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Personally I would go with the 1K bars, but that is only if your statement regarding weights are accurate. Where are you getting the TW numbers from? Since they are often way off in the printed materials from the manufacturer.
2009 Springdale Summerland 2600 TBL
2008 Ford F-150 Supercrew XLT 4X4
Prodigy + Equal-i-zer
4 Seasons Camping Tips & Tricks!
Center Pin
Fort Langley, BC
Posted: 11/04/09 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
What he said. Plus everyone is always looking for bigger bars, so finding someone to trade with should be pretty easy.
Trailer: 07 Tango 299BHS
TV: 2004.5 Dodge 610 CTD 3500 QC 48RE 2wd Laramie SRW, FP Gauge, FASS 95/95, Rhino Lining, Hensley Arrow, Reese Signature Series 5er Hitch, Air Bags & Compressor, Canopy, AL Boat Rack.
Been running B100 home brew June 2008!
b_salgado
Salisbury ,NC,USA
Posted: 11/04/09 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Forget dry weights! What is the GVWR of the TT? Figure 12-15% for tongue weight from the GVWR. My tongue weight is listed at 800#. It is actually closer to 1100# with a little water in the holding tank, 2 30# propane tanks, and a battery. If I fill the water tank, I am well over 1200#. I say go with the 1200# bars. You'll be glad that you did.
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
Dick_B
Palos Heights, IL USA
Posted: 11/04/09 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried asking Equal-i-zer?
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
BarneyS
S.E. Lower Michigan
Posted: 11/04/09 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
With an Equal-i-zer hitch, it is not just a matter of changing the bars. You need to get a whole new hitch head also since the bars are not interchangeable like they are on normal WD hitches. I would use the 1200lb bars that you have now.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
Check out the RV.net Blogs!
Visit our website here
PopsRacer
Okc, Ok
Posted: 11/04/09 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Try it out and just PM me if you decide you want to trade for some reason.
The 10k has been working good for me so far but a 12k would also and I certainly wouldn't mind having a little stronger WD setup.
2005 6" Lifted Nissan Armada LE (Offroad Beast)
2007 Jay Flight 29BHS
__________________________
jmtandem
carson city nv
Posted: 11/04/09 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Crispy,
If the dry weight of your camper is around 6100 pounds, the gross will likely be near 8000 pounds. If 15 percent of that is on the tongue you are in 1200 pound spring bar territory. Best to load it up and then weight the tongue. You might be surprised how heavy it really is.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed airbags overload springs bumpers
Topeka Kansas USA
Posted: 11/04/09 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Good advice from jmtandem above. Use 15% of the GVWR of the trailer to establish the maximum tongue weight of your trailer.
piac
long island
Posted: 11/04/09 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
gosh guys dont complicate things...you will be fine with the 12's...you cant have too much bar...but you can have too little...
