Woodalls Open Roads Forum: Travel Trailers: Lexan or plexiglass on my screen door
 > Lexan or plexiglass on my screen door
mhawk4
South Carolina
Posted: 11/06/09 12:07am Link  |  Quote  |  Print  |  Notify Moderator
I also installed a latch on the screen door after we got the trailer, on our first trip our now 3 years old pushed the screen door and fell head first on the pavement. We were so upset about what happened, the next day i bought the latch and installed it; is been close to 2 years, and we still make sure everyone knows when the kid is inside the latch stays on lock position. (i think we'll stop telling people when he turns 41)
To the OP, i think i am going with Plexiglas. I have a few other mods i will be working during winter break and need to stay under budget. i am planning on changing thermostats, building a slide out extension for the dinette table and a drop leaf extension for one side of the sink.
i think these will keep me busy until we go out camping again.
Hey Turk2500, did you cut the plexi to fit around the hinges or the velcro created enough clearance between door and plexiglas.
thanks for the help
2002 Ford Excursion XLT 6.8L,V10 3.73(TB2)
1999 Chevy Suburban 5.7L,V8 3.73 (BUDDY)
2008 Jayco G2, 27BH (MHAWK)
HP dual cam
Luis,Shelia,Noah,Gabriel
All about the family!!
TURK2500
USA
Posted: 11/06/09 07:34am Link  |  Quote  |  Print  |  Notify Moderator
mhawk4 wrote:
snip.....did you cut the plexi to fit around the hinges or the velcro created enough clearance between door and plexiglas...snip
In my mod, the plexi was cut to fit around the screen door hinges. But yes, the commercial velcro that I used may have allowed for clearance over the hinges.
Check your clearance between the screen door hinge and the outer door with the screen door latched to the outer door.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
gheicher
Pennsylvania
Posted: 11/06/09 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Lexan (polycarbonate)is used for bulletproof "glass" and is extremely strong. Almost impossible to break by bending, and you can cut it with a standard combination blade electric saw. Downside is that if exposed to continual sunlight (ultraviolet rays) it may become a bit cloudy or slightly yellow. My friend has had Lexan on the north side of her screen room for several years and it is has remained clear. Plexiglass is very clear, inexpensive, but brittle and difficult to cut. My preference would be Lexan since it is stronger and easier to work with. If it discolors a bit, it still lets light in and that would be my main concern.
dodge guy
Bartlett IL
Posted: 11/06/09 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
So I take it the best way to attach it is to screw it to the frame? I`ve been wanting to do this for awhile, but I want to make it easily removeable so I can remove/insatll it a couple of times in a weekend. you know windows open or closed.
Wife Kim
Son Brandon 8yrs
Daughter Marissa 7yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear, Hellwig sway bar
Reese HP dualcam,Prodigy brake controller.
A bad day of camping is
better than a good day at work!
Bucky Badger
Madison, WI
Posted: 11/07/09 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Velcro is the neatest and easiest way. Looks way cleaner than the clips people use.
http://weathersticker.wunderground.com/w........big2_cond/language/www/US/WI/Madison.gif
Fred & Jodie, dogs, Zoey & Bella
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
Rallies/Gatherings
IL
WI
willald
NC
Posted: 11/10/09 07:51am Link  |  Quote  |  Print  |  Notify Moderator
..But velcro also does not last, as many will tell you that took this approach and later on wished they had not. The adhesive on the back of that velcro eventually wears out.
Clips OTOH, will last forever basically. Very easy to remove/install the plexiglas also. Just rotate all the clips to the side, plexiglas comes right out.
Dodge_guy: Somewhere, I have some pictures of our installation, with the clips. I'll try to dig them up later this evening, get them posted here so you can see how it looks/works.
Will & Angela
2003 Ford Excursion V10 4x4 ("No Taxpayers were harmed by the makers of this truck")
2003 Thor Citation 33M, Hensley Arrow hitch, Brakesmart Brake Control
Our Rig
Bucky Badger
Madison, WI
Posted: 11/10/09 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I have 2 full seasons and my velcro is fine...I wouldn't mind if I had to replace the velcro every 3 years....Still looks better than the clips.
TURK2500
USA
Posted: 11/10/09 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
willald wrote:
snip.....But velcro also does not last, as many will tell you that took this approach and later on wished they had not. The adhesive on the back of that velcro eventually wears out....snip
Never had any issuies with my Velcro installation, and going on four years. Curious where you found that "many" regretted using Velcro.
IMO, Velcro or screwed tabs both will do a great job, just one's preference.
Turk2500
2halfs
CA.
Posted: 11/10/09 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
As a thought when you decide to do this project. Check in your area for a store that deals with these plastic's...We have one here called "TAPS". They sell all kinds of plastics, tubes, boxes, windows, baseball cases, ball cases, etc... We took our screen door off and took it in. The gentleman listen to what we wanted, what we were doing. asked us a couple question, gave us some suggestion. Came back in less then 10 minutes with the panels cut for our screen door. We bought one extra piece to go on the bottom inside as I have a small dog who likes to paw. I bought the one extra piece so when our came up all scratched from the dog then we would be prepared and just be able to swap out. Well that was three years ago. We are still storing the extra piece.
Getting the three pieces cut (one extra) cost us a whole $25.00.
This method was so eay and fits our screen perfectly.
One other point is to remember as you are doing this, you will be at times when you want the panels on and other times you want to take them off to allow for air flow. So you need to look at how to fasten them on. Make it easy for yourself.
Please share with us what you do.
Happiness in an RV is a Full Tank of Gas,
and an Empty Holding Tank!
JBarca
Dublin, Ohio, USA
Posted: 11/10/09 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Fellow Door Panel Campers....
See this post, 4 pages worth and mine is in there too with more pics.
http://www.rv.net/forum/index.cfm/fuseac........d/tid/22665852/srt/pa/pging/1/page/2.cfm
The first one I did in the pic above was made from Plexiglass, about $50 of material. I cracked one section flexing it getting it on while fitting it . Had enough to make another and it works OK. However on this new TT I will use Lexan as I could not find it before. Home Depot now has it, about $65 to $70 a sheet when I bought it. Like 24" inches by 70" ish. It's still in the shed ready to be cut and fit. Have not made it to it yet.
Mine uses clips. Can take upper or lower panel on or off. However you do this, it is a great mod.
Hope this helps
John
John & Cindy
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we where camping!)
