Woodalls Open Roads Forum: Travel Trailers: How long is too long to tow?
 > How long is too long to tow?
colochoclab
Arvada, Colorado
Posted: 11/17/09 11:18am Link  |  Quote  |  Print  |  Notify Moderator
We travel with the rig in my signature and LOVE it!
My Jayco 29FBS is actually about 31ft and 8k loaded. There are a lot of great floorplans out there most with slides that will fit into what you are looking for!
Here's Jayco's site, but I'm biased! LOL!
http://www.jayco.com/
-Lab
2008 Nissan Titan LE Crew 4x4
2006 Jayco JayFlight 29FBS
Equal-i-zer Hitch
Prodigy Brake Control
Member of clubtitan.org
"Hershey" & "Snickers" My Chocolate Labs!
"I asked God for true friends: He sent me 2 Labrador Retrievers."
DavidP
Raleigh
Posted: 11/17/09 11:30am Link  |  Quote  |  Print  |  Notify Moderator
TXiceman wrote:
First off, 32' plus is way too much to pull with a 1/2 ton vehicle, so as along as you are just looking, look away.
But practically, about 26' is the most I'd attenmpt to pull with a 1/2 ton truck.
There is a lot more to towing than the weights, the tow vehicle has to have the mass and suspension to properly control the trailer. A hensley Arrow is not a cover up fro too much trailer.
Ken
I agree! Anything over 26 Feet you need atleast an F350
dually.
Keith99RS
Suffield, CT
Posted: 11/17/09 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
There is also alot more to towing than length. If you go by the guidelines one usually cited link here (towing tips IIRC) has for TT towing you would not be able to to anything over 35ft no matter what the TV is. Mass in your example, is a product of weight, not length.
To the OP: I am towing a 30ft TT with my 2005 Titam with the Reese Dual Cam. Never had control issues even in 40-50 mph gusts. Just adjusted speed accordingly. Pay attention to tongie weights and don't get suckered into a dry weight purchase. When looking I used the 80% rule (only used 80% of the trucks rated tow capacity) and also made sure the max GVWR of my TT would be under the max tow rating for my truck.
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
DavidP
Raleigh
Posted: 11/17/09 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
Good Advice. TW and GVWR of the trailer compared to your trucks capabilities are critical. Stay at or under the 80% rule and you should be fine. With any properly matched TV/Trailer; in a radically evasive maneuver with a TT behind you the end result will not be pretty. Proper Equipment, safe speed, safe distance and driver skill are paramount.
In choosing my current trailer I wanted to stay within the weights and capabilities of my TV both GVWR and TW and use a good WD Hitch combined with sway control.
eubank
Angel Fire, NM, USA
Posted: 11/17/09 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
It all depends on what you want to tow. Newer rigs are indeed much heavier than some of the vintage rigs. Recalling the point that PopsRacer made above, a vintage Airstream doesn't weigh anything near what a new one weighs. For example, our 67 Airstream, a 30-foot, tips the scales at 4,650 dry (about a thousand more when loaded), and we tow it all over the western mountains with our long-bed F150, small V8. But that's the exception rather than the rule, given that most folks are not interested in vintage rigs.
Lynn
http://forum.aardvarkrv.com/blog/
Hayduke Lives!
JoeGood988
S.Dakota
Posted: 11/17/09 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
The Nissan Titan is a nice truck but it's still a lightweight pleasure truck. Towing is limited to ultralight trailers. When you get into trailers that are 30' or larger, you're heavier than the Nissan can safely handle. The true test is steep mountain grades of 8% or so....you will drop down to a crawl on a huge hill...then smoke the brakes coming down the other side. They don't put heavy duty brakes on either. Be safe, stay small until you can upgrade the truck to a 3/4 or 1 ton truck rated to safely haul what you need or desire.
2003 3330 Jayco Legacy
redwake
Visalia, CA
Posted: 11/17/09 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
something else to think about... what is the length really giving you? my space problem comes in width not length would be solved if i had slides or removed my dinette.
but until i have time to work on a slide when it breaks i dont want a slide and my 1 yr old sleeps in the dinette presently so i'll live with the 4 members of my family squeezing behind me while i'm on the stove for now.
TT: 08 Monterey 27 PT by Extreme RV
TV: 06 Sierra K1500 SLE Crew - 3.73:1 4x4 w/5.3L
Hitched with a Husky WD & SC.
Powered by Champion 3500
HappyTrails2U2
Atlanta, GA
Posted: 11/17/09 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I've never towed travel trailers but I have towed a lot of heavy utility trailers and car haulers in my day.
I don't see how length matters as far as towing ability is concerned other than getting in to tight spots as has already been mentioned? It could be 100 ft long and if it only weighted 1,000 pounds it pull like it wasn't even there. On the other hand if it was only 10 feet long and weighted 10,000 pounds you've got a problem with a small truck.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 4.8 Extended Cab
Jet Computer Programmer
True dual exhausts and Magnaflow Mufflers
Hayden Automatic Transmission Cooler
pauz11
Vancouver, Canada
Posted: 11/17/09 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I think the assumption is that if you switch from a 27' w/o slides to a 32'+ slides, the weight is going to increase dramatically. Be prepared to eat up brakes and possibly calipers on the TV. Have them checked before you notice any issues or sounds.
2005 Silverado 3500 DRW
2006 Okanagan 26RLS
ch47d99
AL
Posted: 11/17/09 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Wow. The weight police are out again on this one...even more restrictive than normal. Now the 1/2 tons have to stay under 30ft, even if it is a lighter weight trailer. It is your choice, but I disagree. A 32 ft trailer at 7-8K GVWR is still well within the 80% rule of thumb of a big tow Titan's max tow rating. Plenty of Titan owners pulling these size trailers...and F150 owners, and Tundra owners, and Ram owners.
