Woodalls Open Roads Forum: Tow Vehicles: GM 6 Speed Shifting
Search only in Tow Vehicles
 > GM 6 Speed Shifting
revrnd
Apsley, Ontario
Posted: 11/18/09 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious if there's anyone out there using a 6 speed equipped GM truck as a TV. I was looking @ some pics of a 2010 2500HD & I see the shifter "quadrant" was like this:
P R N D M
Should I assume selecting D will allow the tranny to shift up to 6th (the 2nd OD gear)?
What does M allow the tranny to do?
When towing what do you guys use?
1986 Monte Carlo SS
2004 Chevrolet K2500HD (P3 controller, WD hitch T.B.D.)
2009 Rockwood 2106 Mini Lite
Retired GM of Canada Oshawa Truck Assembly Plant
Opened 1965 Closed 2009
Golden_HVAC
Fulltime, CA, USA
Posted: 11/18/09 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
The Cadillac that I drove has a M setting. There is a up and down arrow on the shifter column, and that will allow me to shift to 5, 4, 3, 2.
I usually just left it in D, and let it do it's thing. But if you are going down a long hill, then shifting to M and then using 5, 4, or 3 as the highest gear the transmission can shift into can be an advantage, especially when you are needing to use the brakes a lot, but simple engine braking can handle most of that braking load, saving the service brakes from overheating.
Make sure that you are not using lower than 4 gear at freeway speeds, and use the tachometer to make sure you are not over revving the engine if you have one. I would not want to go over 4,500 RPM. I would use the brakes to bring the speed down so the RPM is around 3,500 or so. Or downshift another gear, and slowing to less than 3,200 RPM before downshifting another gear will keep the truck from jerking when shifting down.
Good Luck,
Fred.
revrnd
Apsley, Ontario
Posted: 11/18/09 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Fred, thanks for clearing things up. 1 of the other pics showed the shifter w/ the tow/haul switch & the up/down switch.
1 more question, when you're using the up/down switch is there any indication on the dash as to what gear you're in?
TomG2
Central Illinois
Posted: 11/18/09 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, on the 2500 HD, it indicates with a number beside the M which gear you are in. M3, M4 and so forth. It can be manipulated like a standard shift, by + up one gear at a time and - down one gear at a time. Great control. I suspect they copied the operation of the Allison transmission.
glazier
Kentucky
Posted: 11/18/09 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
When towing use Tow Haul and D, this will allow the truck to downshift on hills. I use the M (manual) on slick roads, and when decending long curvy hills. There is nothing I would change on my truck, everything functions perfectly.
2010 Jayco Eagle Super Lite 31.5 FBHS
08 Chevy 2500HD LTZ Duramax CC/SB/4X4
Reese Signature Series Hitch
Earl E
Where the RV is parked (formerly OR)
Posted: 11/18/09 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
It works beautifully. You seldom need the M setting if towing. Just put it in Tow mode and the Allison will work for you great. Because there are six speeds it is just too many places to shift by pulling the gear shifter up and down. The M setting lets you do it by pushing a button.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
Follow our Trek Across America at
http://barbandearl.blogspot.com
revrnd
Apsley, Ontario
Posted: 11/18/09 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I'll be ordering a 6L, so the Allison won't be in the equation.
NC Hauler
Asheville NC
Posted: 11/19/09 12:50am Link  |  Quote  |  Print  |  Notify Moderator
On Edit: I was writing about the D/A and I just noticed that your talking about the 6L gas engine, my bad...don't know that much about the tranny that comes with the 6L engine...sorry about that...
Jim & Kathy
07.5 Chevy K3500DRW/CC/LB/LMM/D/A/6speed/ LTZ,Prodigy,Reese 20K Ht.
08 Jeep Liberty Sport 4X4
06 HR Presidential Suite 37RLQ (39' 6")4 slide
09 Hyundai Accent SE (resting the Dually some)
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
TomG2
Central Illinois
Posted: 11/19/09 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Like I said earlier, the GM six speed appears to emulate the Allison transmission. In the Owner's Manual, most instructions are identical.
nevadanick
Elko, Nevada
Posted: 11/19/09 07:40am Link  |  Quote  |  Print  |  Notify Moderator
So this transmission behind the gas engine will hold back like an Allison ? I've asked at the local dealers and they dont have the answer.
