BlownL36
Jackson, NJ
Has anyone had an older TT and Had Fake Wood on the outside? Im looking to change it out and just wanted some ideas.
Sean & Jessica
Wonderful Little Girl
1998 Chevy 1500 Van.
1978 19FT Coyote
2004 Mystichrome Cobra 620whp/679trq
BuckBarker
Overgaard, AZ
Fake vinyl?
mjonags32
SF Bay Area
Fake wood for outside? Your best bet would be vinyl sticker
**1984 Komfort Lite Travel Trailer**
BEFORE & AFTER pics
2007 Toyota Tacoma
MANY mods:
CARDOMAIN LINK
BlownL36
Jackson, NJ
Yea it looks like laminate wood. Fake stuff. Its all discolored. Wanted to know if i could put 1/4 inch wood in and seal it with polyurathane. I think that would look nicer then wats on it.
Todd Barney
Atlanta area, GA, USA
Would need to be Spar Urethane - the kind used on boats. At least 3 coats, probably more, if you want it to last.
2006 Maxlite 30BHS
Maxlite Photos
Large: 2003 Dodge Ram 2500 Quadcab 4x4 V-10 5spd manual 3.73
Equal-i-zer, Prodigy
Medium: '07 Infiniti G35S
Small: '91 Miata
Pad the walls, we got 10-yr-old twins in here!
BlownL36
Jackson, NJ
Would the spar urathane be a Home Depot? Or would i have to go to like boaters world for it?
Charlie D.
Gonzales, La.
You can get Spar varnish at any store that sells paint. Spar varnish, although made for exterior, will still flake and peel after several years.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
Opie431
Bellevue, MI
Way in the past I saw TTs with metal painted to look like wood.
dublittle
Florida
I recommend you do not use polyurethane spar varnish from the Borg. I have tried it on a wooden mailbox and it hardly lasted a year. I have had better luck with a marine spar varnish. Epifanes is one of the best. You will still need to put on several (4+) layers and expect to refinish frequently. I also use Epifanes on my wooden canoes but since I keep them under cover most of the time, I have only had to touch up scratches in the last 7 years.
