Woodalls Open Roads Forum: Class C Motorhomes: No electricity at refrig. outlet
 > No electricity at refrig. outlet
sunlight
Durham,N.C.
Posted: 11/19/09 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
YC-1 I meant the roof air. I am hooked up shoreline but I forgot whether what I have is a 30 or 50. Pigtail? It is flatbacked with the 3 prongs. Doug
ShapeShifter
Buffalo, NY
Posted: 11/19/09 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
sunlight wrote:
Thanks for everyone's help, I will have to look, I don't think there is a GFI outside. Would it be in the rear of the refrig. area?
If there is a GFCI, it could be anywhere. Inside, outside, near the refer, or even on the far side of the rig.
enblethen wrote:
I would suggest buyiing an inexpensive circuit tester. These have three LEDs. You simple plug them into your receptacles to see if they are wired correctly and they will give you some insight as to what the problem is siuch as open phase conductor, neutral or ground. About $5 at local hardware store.
Good suggestion! But I would recommend spending a couple dollars more, and getting one with a GFCI test button on the side of it. It does everything that the three light tester does, plus tests GFCIs. This is useful for testing the outlets that are downstream of the GFCI to see if they are really protected, as there may be some wiring errors or fault conditions which might prevent a fault at a downstream outlet from tripping the GFCI. It can also happen that the test button on a GFCI can fail -- it will still trip on a fault, but the test button doesn't make it trip. The trip button on the tester can help isolate this, as well.
enblethen
Moses Lake, WA USA
Posted: 11/19/09 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
ShapeShifter:
Some newer models have the red LED indicating they have power and are operating. Older ones did not have indicators. Just the colored buttons.
Bud
Suzuki XL7 pushing Pace Arrow
ShapeShifter
Buffalo, NY
Posted: 11/19/09 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
ShapeShifter:
Thanks for the clarification, that matches with what I've seen. Your prior post seemed to be saying the opposite -- maybe I was reading too much into it?
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
