Woodalls Open Roads Forum: Travel Trailers: Winterizing?
 > Winterizing?
silver pony
North Carolina
Posted: 11/20/09 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
I am new to posting here even though I have been reading and learning a lot this fall. I bought a 23 ft. camper this summer and have loved camping at horse shows which I attend often. I am now ready for winterizing. I really don't have a clue where to start so I am open for advice from all you experienced campers. Thanks for all the help!
usmc616
Orange County New York
Posted: 11/20/09 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,What i do is I empty all holding tanks.Then I open all low point valves, I remove the drain plug on the hotwater tank and open all the faucets. I blow low pressure ( no more than 40psi) air with my compresser through the city water hookup. I then bypass the hot water heater and close all faucets. I then pump rv antifreeze through the system. As the antifreeze is going in to the system I ensure it has come out the low point drains and then I close them. I then go to the furthest faucet, open it and then close it once the pink stuff has come out. After all lines have had anti freeze run through them I then pour some into each drain and the toilet. I place steel wool into all furnace exhaust vents and leave at least one roof vent slightly open. I am sure other will chime in with things I missed as welll as their own methods, but this is a good start. Good luck, Joe
Semper Fi
Joe, Joyce 4 kids and 2 dogs
2004 Ford Excursion LTD. 4x4 6.8 V-10 3.73 Gears
2010 Jayco G2 32BHDS at dealer.
2oldman
Indio CA
Posted: 11/20/09 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
winterizing in section 23 of FAQ
Winterize Sept 2009
Winterize with air pressure
Black tank flush winterize
Leave tanks empty?
Water in black after empty?
Winterize batteries Oct2009
Clarryhill
Midcoast Maine
Posted: 11/20/09 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Silver Pony, welcome to the forum, a truly great place for help and guidance. 2Oldman's list is really a great set of references for someone just getting started. Happy Camping.
2005 GMC 2500HD D/A
2008 COLORADO 31 RL-BS
albertaborn
Calgary
Posted: 11/21/09 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
One I use
http://www.bitware.com/5er/winterizing.htm
north trail 31 QBS
Dave & Nannette
Burley Idaho
Posted: 11/21/09 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
If you never winterized your RV before, like I understand you haven't, you may not understand how to pump the Pink RV antifreeze through your system. I didn't when I first got my RV, but it is easy to do. It should be possible to do with any RV with a pump installed. All is needed is a syhpon adapter. RV antifreeze and maybe 5-10 minutes.
Some RV's, I'm told, has a syphon adapter but if yours doesn't buy one. Connect the adapter to the intake side of the pump, stick the syphon tube down the RV Antifreeze bottle. Best if you have another person who turns each faucet on one at a time till they see pink. This is done while the other person quickly changes the bottles by the pump. May be a better way, but works for me. My RV took less than 3 bottles.
Some people do take a shortcut and just pour antifreeze in the fresh water holding tank, then pumps the stuff through, this is an easier way and an adapter is not needed. But there is good reason not to do it this way. It seems nearly impossible to flush it all out when you dewinterize it. There is always a little in the edges or somewhere in the tank. Eventhough a little of the stuff wont hurt you, the smell and taste is very bad.
* This post was edited 11/21/09 07:21pm by Dave & Nannette *
U.S. NAVY RETIRED (active duty '72-'93)
'03 FORD F250 POWER STROKE SUPER DUTY TURBO 6.0
'04 KEYSTONE SPRINTER 27' (One Slide out)
1 DOG - SHIH TZU (MOLLY)
Widower; My wife (Nannette) recently passed away, but I'll keep the name "Dave & Nannette"
stephend
Ashville, AL
Posted: 11/21/09 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
I don't blow the lines out. Drain water heater and fresh water tank. By-pass water heater. Pour 3 gallons pink RV antifreeze in fresh water tank. Open each faucet until pink runs out runing water pump. Then use a 4th gallon to open the toilet to pour some in the black water tank and pour some down the bath tub to get some in the grey water tank. Lastly fill the sink and bath tub traps. Done!
3 married children, 2 gr ch
Electrical engineer married to mom/homemaker
New Log Home on lake lot to retire in 8 years
Not golfer, fisherman or hunter but Let's go camping!!
2006 Silverado Crew Cab 5.3L 3.23(Transm temp gauge)w/2005 Springdale 281 RKS
silver pony
North Carolina
Posted: 11/23/09 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all of you for the help. I have winterized successfully! Well at least I hope, guess I'll know in the spring!
cremevette
NE Ohio
Posted: 11/23/09 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Great instructions, and thank you. But one question. I would do my own winterizing and save $50 if I knew how to property empty the hot water tank. I tried it a year ago and the dealer's service department checked it and said I hadn't done it right. I have a valve installed into the anode rod and was told that all I had to do to empty it was turn that valve. Wrong. Supposedly there is another valve at the top of the HW tank also that allows the air in, and therefore the water out. Anyone know where that valve is? I sure haven't seen it. Maybe it's on the inside of the TT??
Claudia
2007 Keystone Springdale 266 RELLGL - The Bungalow or "Hen House"
2005 Silverado 2500HD 6.0 - Little Red
Atwood Power Jack, Reese Pro Series WDH, Champion & Honda EU2000
Nights in 2009 - more than 50, quit counting
 > Winterizing?
