Woodalls Open Roads Forum: Ford Cruise Control Recall - Fix Verification
 > Ford Cruise Control Recall - Fix Verification
pauldub
North of Seattle
Posted: 11/20/09 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
I took my moho in for the cruise control fix today and it's not obvious that they did anything. How can I tell if they really did the fix?
PapPappy
Wilmington, NC
Posted: 11/20/09 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
It won't malfunction and cause you to crash
Yeah, like you, mine was working fine before I took it in, so now it's still working fine....and I can only assume that they did the repair. I guess if there is a problem, and it is caused by the cruise control, you can have it checked and maybe sue Ford....but I'd rather not have that crash!!
My advice...use the cruise control when you are on open highway, where there won't be much problem, if there is a problem......and don't use it on rainy days, where you may find yourself out of control. Good advice for the CC in your car too!
happy Camping
Bill & Claudia / DD Jenn / DS Chris
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie & Beau
RIP: Cookie (Sheltie) & Gidget (Lab-mix) over the Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
nickelAF
Charleston, WV
Posted: 11/20/09 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I'm under the impression the fix is to add a fuseable link to the harness. If the device fails it take out the link preventing a fire.
07 Arctic Fox 31WRB
04 6.0L 4X4 Excursion
garym114
Posted: 11/20/09 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look at the brake master cylinder. There is a switch connected to the bottom. It has new wires connecting the switch to the wiring harness. The new wiring includes a fusible link to prevent too much current draw if the switch fails and leak brake fluid.
Get a Digital Multimeter and Learn How to Use It
2000 Sea Breeze F53 V10 - CR-V Toad
Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
Golden_HVAC
Fulltime, CA, USA
Posted: 11/21/09 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for that information.
I will have to check my motorhome, and perhaps get that recall done sometime soon!
Good Luck,
Fred.
Whiteline
San Diego CA
Posted: 11/21/09 06:38am Link  |  Quote  |  Print  |  Notify Moderator
When did this recall come out. I have a 09 E450 and have received nothing. Did I miss something here. Thanks Guys
Bob
2009 Jamboree Sport 2006 Honda CRV
Harveyj
Boise, Idaho
Posted: 11/21/09 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Call your local Ford dealer and give them your VIN number....they can tell you if you if your vehicle is effected. When I had my Winnie fixed, it took less than three minutes to add a small wiring harness to the master cylinder.
pauldub
North of Seattle
Posted: 11/21/09 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I know where the switch is but I see no new wires. It looks the same as before they did the fix. Is it possible the fix is a new connector to the switch?
jberts
St. Louis, MO
Posted: 11/21/09 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Important Notices
13 Oct 2009
Speed Control Deactivation Switch Recall (09S09)
Ford is recalling all remaining vehicles – approximately 4.5 million U.S. vehicles – equipped with Texas Instruments speed control deactivation switches. While the data show the majority of the vehicles being recalled do not pose a significant safety risk, we are recalling the vehicles to reassure customers and eliminate any future concerns. This recall affects older models, including discontinued vehicles. The majority is greater than 10 model years old, with some up to 18 model years old.
From Ford.com website. You can put your VIN # in and it will tell you if there are any recalls on your vehicle.
woodworker414
Crystal City,Mo.
Posted: 11/21/09 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
I had the fix done, took maybe 8 minutes, a fuseable link was installed, it is easily over looked, but it is there.
Bill
KDØKLJ
2003 Gulfstream Cavaleir 29.5 V10 E450 normal bells & whistles
