Woodalls Open Roads Forum: Toy Haulers: Funrunner problem???
Search only in Toy Haulers
 > Funrunner problem???
shepcal
Oakhurst,California
Posted: 11/20/09 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 162FL toyhauler (bought new), which I use to haul a quad and go to the desert to prospect. I know I'm well under the 7K Gross vechicle weight. It's made 8 trips of approx. 1200 miles each.
I just replaced tires and noticed they have been rubbing the top of the wheel wells (it's just wood and this isn't good!). I'm in conversation now with Carson Trailer. They suggest new springs and a 2" tubing which goes somewhere?; which will give 4 1/2" clearance (but at my cost)
I'm looking for anyone, with a TH of similar size. I have 1 1/2" clearance between top of tire and wheel well on all 4 tires; empty and level. Does'nt seem right to me???? Can anyone w/ a similar Fun runner, give me their clearances????
Thanks, Shep
trxcr
elko nv
Posted: 11/21/09 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I have a Carson Rebel and just went out to look at it. It's has one quad in it and it looks like it has at least 4 1/2". No rub marks and I've hauled two sport quads in it before.
Lord, grant me the senility to not recognize the people I don't like, the good fortune to run into the ones I do, and the eyesight to tell the difference
OlderThanSand
Tollhouse, Ca
Posted: 11/21/09 09:52am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking that if all was well with your trailer when it was new your springs may have lost their arch. If that's the case try Redneck Trailer in Fowler or Century Wheel & Rim in Fresno. If I remember right it'll cost you about $100 to replace them.
2002 4x4 Super Duty PSD
2006 22' Carson Titan
2009 Polaris RZR
2007 Suzuki LTZ 400
2007 Honda TRX 250EX
1995 model dune crazed granddaughter
shepcal
Oakhurst,California
Posted: 11/22/09 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Appreciate the replies. 4 1/2"? Didn't remember, having that much clearances, but last night; I went through my old pic's and sure enough! A month after I bought it, the top of the tires are almost even w/ skirts and that was loaded w/ my quad!
Still waiting for a response to my second set of questions w/ Carson, but will check w/ the aftermarket places, in Fowler and Eberwein(sp?)Springs, if they are still in business in Fresno. Might even be able to get a little more arch added.
Thanks, Shep
shepcal
Oakhurst,California
Posted: 11/23/09 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Talked to someone at Carson this morning, not person I talked to previously, he said I had problem w/ bent axle, that threw the camber out and could give me number of where they buy their axles (Must of had a real bad weekend!)
Called Tru-Trailer in Fresno, where I bought it originally. Tom said he'd look at it, if I brought it down. So, went home and took it down. He said a definite drop and had the same springs in stock and suggested the shorter shackles. Also mentioned going to the 4K springs w/ the shorter shackles, but they'd have to be ordered. I went that route.
Main reason for this post is, to the newbe's. This was my first Toyhauler. This trailer works great for me. I opted for the larger refer, but didn't know about all the insidentials, one might encounter. I've changed the converter to a 3-stage, went to 2 batteries (solar's next) and now this. To the newbe when buying new- kind of know what you want, then do a good search on this forum for any problems and address them to the seller. The problem w/ my springs might be a fluke, but going the next size stronger, might be good, if it's not to solid and shake my cabinets off the walls ;-)
Take care and thanks for the input of some
Shep
big buford
Buena Park, Ca
Posted: 11/24/09 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Might want to check into a dexter e-z flex or mor ride shackle kit. Now would be a good time while it's all apart.
Safe travels, Mark
"My drinking Team has a racing problem"
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat Subaru pwr
06 Rhino
06 Raptor 700
Beautiful wife that's much nicer than me
shepcal
Oakhurst,California
Posted: 11/24/09 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Mark, forgot to add, I'm also getting shorter shackles w/ the springs.
big buford
Buena Park, Ca
Posted: 11/24/09 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Incase you havent seen this thread, some good reading in here.
CLICK
shepcal
Oakhurst,California
Posted: 11/24/09 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks alot Mark! ;-) Read that complete set of posts and then the ones for installation and I can see more money flowing out!
Shep
big buford
Buena Park, Ca
Posted: 11/25/09 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Got a set myself. If your pullin 1200mi trips I think it would be a great investment for your rig.
