Fishcamper
Orleans, MA
This is not about putting a long bed camper on a short bed truck or vice versa. It's about the relative merits/drawbacks of long and short bed trucks and campers.
I have a long bed truck and camper (Lance 920). I don't need the long bed for hauling other than the camper and I have been considering the advantage of a short bed truck and matching camper. For instance, I'm thinking I could change from a regular cab to an extended or even a crew cab without having an unnecessarily long wheelbase when the camper is off.
So, in summary, assuming the 8 foot bed is not needed, are there disadvantages to going to the short bed (assuming I pair it with an appropriate short bed camper)?
2011 Chev 3500 SRW 4X4 gasser - 1999 Lance 920
trail-explorer
NM
Not sure about Ford or Dodge, but in a Chevy, the short bed only has a 26 gallon fuel tank. Long bed has about a 32 gallon tank.
Chevy - dually is only available in a long bed.
Chevy extended cab (suicide style rear doors) - when you open the rear doors, they are going to smack in to the camper jacks! Not sure if this would also be the case on Dodge or Ford because I don't know how far out the doors swing open.
Jim
racedrvr
Chicago Burbs/Kentucky Lake
I went with the shortbed for the reasons you are considering. I don't consider my having made any sacrifices except the choices of longbed campers are greater than the fewer made shortbeds.
My Chevy extended cab rear doors do not hit anything on the camper when opened fully.
Chevy Silverado LT EC 2500HD 4X4 Duramax/Allison. Airbags, Rancho RS9000XL, Torque Lift/Fastguns, Torklift superhitch, Hellwig swaybar, Hypertech Hyperpac, Honda eu2000i
Bigfoot 25C 9.4
jimh425
Western WA
Short beds have more percentage of the weight behind the rear wheels. This problem is even worse with a Crew Cab compared to an Extended/Super Cab. Short beds with the same length camper will also have a longer overhang. This makes pulling a trailer slightly more complicated.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
SoCalDesertRider
SanDiego, CA, USA
The late model Dodge Quad Cab doors swing open forward like a normal crew cab. Early model Dodge Quad Cabs had suicide doors. I think the change happened somewhere around 2000.
The longbed makes more sense for carrying a truck camper, especially any truck camper longer than 8 feet, cause the axle is further back, having less weight behind the axle and more weight distributed to the front axle.
On most trucks, an extended cab short bed is about the same length as a long bed regular cab and an extended cab long bed is about the same length as a crew cab short bed. The best compromise for hauling a truck camper is the extended cab long bed, if you're worried about wheelbase length.
If you're getting along fine now with a regular cab, then obviously you don't really need a crew cab, you're probly just looking for some more interior storage space and occasional passenger room. The extended cab fits that scenario very well without making the truck unecessarily long while still keeping the full 8 feet of bed length for carrying a wider variety of campers and/or a longer camper. The long bed also allows carrying an 8 to 9 foot camper and towing without an aftermarket heavy duty hitch and extension bar that are needed to carry 8 to 9 foot campers with a short bed.
05E350 6.0PSD
97F350DRW 7.3PSD 4x4 4.10 11' flatbed
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
fishfinder
Colorado, USA
I have a short bed, but wish I had a long bed and a longer camper. I prefer having the back of the camper flush with the back of the truck because it makes backing up easier for me, and I tow a boat (in the summer).
The rear doors on my '08 Chevy don't hit the camper jacks, but it's close.
fishfinder, Colorado
'08 Chevy K1500 Ext.Cab 5.3L/3.73
'03 Phoenix Pop-Up Truck Camper
'98 Four Winns 18' Fish & Ski Boat
Super_Dave
Sacramento, CA
All it took to prevent my doors from hitting the jacks was to put a 2 X 4 between the camper and the front of the bed.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
trail-explorer
NM
I guess I'm way off base on the extended cab rear doors on the NBS chevy trucks. I've seen pictures of how the doors will open almost 180 degrees (flipping all the away around against the truck bed) so I assumed they'd hit the camper jacks in doing so.
My biggest reason for wanting a long bed was to get the 32 gallon fuel tank.
s1214
Vt
One thing that has not been mentioned is that on some models, the long box will cost you a couple hundred pounds of payload compared to a comparable short bed.
Did I understand the comment about weight behind the rear axle? Are you saying that loaded there is more weight, or are you saying empty? Loaded I can understand that it would be a concern, but you would get the same affect with any camper that extends beyond the box sides. As long as the center of gravity is in front of the rear axle it shouldn't matter what size box.
DWeikert
York, PA
trail-explorer wrote: I guess I'm way off base on the extended cab rear doors on the NBS chevy trucks. I've seen pictures of how the doors will open almost 180 degrees (flipping all the away around against the truck bed) so I assumed they'd hit the camper jacks in doing so.
The rear/suicide doors on my Chevy do open to almost 180* but they also have a detent at 90*. I rarely open them the full 180.
The 26 gallon tank is annoying.
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
