Woodalls Open Roads Forum: Truck Campers: Air Deflectors?
Search only in Truck Campers
 > Air Deflectors?
hard3
southern Illinois
Posted: 02/04/10 07:14am Link  |  Print  |  Notify Moderator
Has anyone experimented with any type of air deflectors to change the turbulence between the cab-over and the roof of the truck? My f250 super cab has a bad problem with the wind forcing the door gap open . does not seem to be a problem unless camper is on. I was thinking of some sort of deflector to redirect the air stream to go around instead of under the gap. Any ideas? Maybe a trim tab like device under overhang ?
shanty66
mastic n.y.
Posted: 02/04/10 07:20am Link  |  Print  |  Notify Moderator
Do a search and you will find some god ideas, they are out there. Enjoy--LOUIE
bobndot
USA
Posted: 02/04/10 07:28am Link  |  Print  |  Notify Moderator
I think sleepy has one under his cabover. If i remember right, its a nice neat looking air deflector . im sure you'll hear from him when he awakens.
TheLesserest
Anywhere
Posted: 02/04/10 07:44am Link  |  Print  |  Notify Moderator
I went and checked out a truck camper at a campground and the guy had the neat idea of getting an air mattress and folded the corners in before he blew it up, thus making an arrow shape. Placed it between the roof and cabover and he said he got 1-2 more mpg. doesn't sound much but over long distances it adds up. I suppose if you have a big space, you can have two of them together.
TheLesserest (Less)
Jayson. A Future Truck Camper!
SoCalDesertRider
Arizona desert
Posted: 02/04/10 08:10am Link  |  Print  |  Notify Moderator
I had thought of mounting a fifth wheel air deflector on the roof of my truck, since my east-west cabover didn't extend the whole length of the roof of my crew cab truck. I never tried the idea though.
On another truck and camper, I had one of those air bags between the roof and camper. All it did was rub the paint off the roof of the truck and then it popped when I hit a big bump that was it for the air bladder.
Pop used to run a thick piece of mattress foam between the back of the cab and camper, with a hole cut out to match the openings of both sliding windows. The foam worked good at keeping the wind out. It did get water soaked in the rain though. A vynal or other waterproof material covered foam would have been better. It did rub the paint off the back of the cab a bit though.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
wayward1
rockbridge, ohio
Posted: 02/04/10 08:21am Link  |  Print  |  Notify Moderator
Hard3,
Do you have vent shades over your windows? Seemed to help with my f350 CC
Rick and Kristi (KNR)
billtex
RI
Posted: 02/04/10 08:26am Link  |  Print  |  Notify Moderator
I have a Thule rack with deflector that we use for kayaks, etc when towing the AS. I have not tried it with the TC on but plan to next month when I take the TC out of hibernation.
I am thinking of just the front Thule bar with deflector might do the job if I put it far enough forward on my cab.
Stay tuned...
Bill
2006 Chevy D/A CC
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
hard3
southern Illinois
Posted: 02/04/10 08:50am Link  |  Print  |  Notify Moderator
I'm thinking of some sort of tabs mounted to the overhang to deflect the air around to the sides instead of in between the roof and cabover. Something similar to trim tabs on a boat.
sleepy
Oak Ridge,Tennessee
Posted: 02/04/10 03:39pm Link  |  Print  |  Notify Moderator
Everything you might want to know about the airfoil
It's almost impossible to find in the TC University... the title needs to be changed and attributed to me. The person that put it in the TCU wasn't too impressed with it.
The more than 60 people that have made them and installed them by and large swear by them.
I'm in the latter group.
If you have a question I'll be glad to answer AFTER you've read the * pages in the thread that you click on here.
Sleepy
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
sleepy
Oak Ridge,Tennessee
Posted: 02/04/10 03:49pm Link  |  Print  |  Notify Moderator
The airfoils in the last 2 pictures above were for a extended cab truck.
The assembly is similar... the cross piece isn't needed on a crew cab.
The front on a crew cab truck is about 22 inches accross instead of being so pointed.
sleepy
 > Air Deflectors?
