Woodalls Open Roads Forum: Class A Motorhomes: How Tall
 > How Tall
RayChez
Barstow, Ca. USA
Posted: 02/27/10 12:03pm Link  |  Print  |  Notify Moderator
My coach is 13'to the top of my KingDome, so if your coach is the same, the door opening alone should be at least 14' high and the building at least sixteen feet. Give yourself a little room to the top and the sides.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 GMC Terrain SLE
FMCA member
thunderstruckhd
Ft.lauderdale and Key West,Florida
Posted: 02/27/10 12:08pm Link  |  Print  |  Notify Moderator
Why do you need to know how tall "Mine" is ???
Are you making space for me ???
Just for the record mine is 13'2
Prevost H3-45 Featherlite Vantare
500HP Series 60 Detroit Diesel
Assorted trailers,toys and toads
And Zoie the Doberman.(01/26/01 - 07/23/11) R.I.P.
fishboat1
southern ca, SW Riverside County
Posted: 02/27/10 12:24pm Link  |  Print  |  Notify Moderator
New Tiffins list the height at 13 feet to the top of the satellite dome. My antennas clear at 13 feet 1 inch. go for 14 feet as suggested. My width is 12 feet which works fine. Leave room for future new MH purchases as they seem to get taller.
Mike H
2007 Allegro Bay 34XB FRED
2002 Dodge Dakota 4 wheel drive Toad 4.7 v8
Four Winns fishing boat
Daboo
Texas Panhandle USA
Posted: 02/27/10 04:50pm Link  |  Print  |  Notify Moderator
I have a "carport" it has a 14 foot clearance overhead..there is one thing I wish I had done...I back the rv in, and the doors on the compartments won't open all the way...wish I had built it 16 wide instead of 14 ft...this is one place where size does count...good luck
Served proudly 1957-1965..U.S. Air Force
barnaclebill
Atlanta Michigan or towards the sun
Posted: 02/27/10 05:21pm Link  |  Print  |  Notify Moderator
My first door was 12' high, after $1500.00 more $$$ it is 13'8" high. The first M/H fit fine but then we deceided to upgrade and...................... You know the rest!
2003 41' Newmar Mountain Aire
400 Cummins
Jeep Liberty
Blue Ox Brake Buddy
admiral0647
Illinois
Posted: 02/27/10 02:46pm Link  |  Print  |  Notify Moderator
Remember, an overhead door that is 14' high (most states have a 13'6" max vehicle height limit) will require higher interior height under the rafters for the door. Sidewall height for standard overhead door might need to be 16'. A front slider door or doors will get buy at 14' with 14' sidewalls on an end opening. A side opening door will require room for a header (10-12") above the door opening.
If you specify an odd sidewall height like 14'3" or 15', each standard length piece of siding (16')will need to be cut, resulting in waste in material and dollars for labor.
In any event a 14' high minimum door opening should take you all the way.
My 30'x 50' pole barn has 12' high walls and 11'9" high doors (after pouring concrete floor). I needed to get 2 low profile AC units installed on my 2007 Class A to get it in.
I started with nothing... and have most of it left.
Damon Challenger 377c
Toyota Yaris Dingy
Scottish Terrier
John S.
Valley of Virginia
Posted: 02/27/10 03:37pm Link  |  Print  |  Notify Moderator
I put in a 14 by 18 foot door. It makes backing in a breeze. I can fit any motorhome of legal height in there too as the inside is 16 foot high.
ALso make sure you put a man door so you can get in and out without lifting the big door all the time.
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler for 300k miles
2012 Jeep Grand Cherokee Overland
Susie and Dolly (Cavalier King Charles Spaniels) now in our hearts and thoughts
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
Salianron
Lake Livingston, Texas
Posted: 02/27/10 04:47pm Link  |  Print  |  Notify Moderator
Hey Toyman,
I had not planned to buy anything much taller than your Sprinter when I designed my building, but I'm glad I made the center door 12 feet high because I now have my eye on a Winnebago Via (Class A minus) which is just under 11 feet tall. Drive on down the penensula past the marina and you will see several tall motorhome garages. Send me a PM if you want to check out one made for an Allegro Bus.
Ron
Salianron --Sally and Ron
2003 Roadtrek 200 Popular
pianodan
Pine River, MN, USA
Posted: 02/27/10 12:36pm Link  |  Print  |  Notify Moderator
I would go with 14x14. My coach is 12'8" at the tallest point and only 96" wide, so I'd have a lot of room, but I'll probably have a larger one sometime.
The OP has a classic GMC coach, so it really only needs a 12' door (look at his sig line), but again if he plans on buying a larger coach sometime, make the structure that will accomodate it.
'91 FRED 35' Oshkosh Journey ('89 chassis)
'93 6BT5.9L Cummins 230 HP TC wastegated/intercooled,Allison 545 4 speed
'74 Jeep CJ6
'80 Suzuki GS850L
FMCA F326065
Pine River, MN
BT1(SW)USNret '95
big jimbo
Carson City, NV/Surprise, AZ./Florence,OR
Posted: 02/27/10 07:09pm Link  |  Print  |  Notify Moderator
My garage opening ie 12 wide and 14 high. Glad I didn't build it any smaller, the additional width allows the mirrors to not have to be moved.
Jim and Sally and a Lakeland Terrier named Rufus
Carson City, NV/Surprise,AZ/Florence,OR
2001 Country Coach Affinity, 40'
Towing a 2005 Ford Explorer Sport Trac with a Blue Ox tow bar and using a Brake Buddy.
 > How Tall
