Woodalls Open Roads Forum: Tech Issues: Norcold Rv Fridge code C2 is on
 > Norcold Rv Fridge code C2 is on
julie3872
georgia
Posted: 04/25/10 11:38am Link  |  Print  |  Notify Moderator
Need some advice about what could be wrong or what I could possibly do about my RV frig (1997). I have defrosted it but it did'nt make a difference and it continued to beep. Does anyone have any experience with this? Is this anything I could fix on my own? Thanks.
want-a-be
On the road
Posted: 04/25/10 12:12pm Link  |  Print  |  Notify Moderator
Go to www.bryantrv.com there you may find a manual on your Ref.
Good Luck
heaterswa
Plainfield, IL. USA
Posted: 04/25/10 05:06pm Link  |  Print  |  Notify Moderator
Same issue running on gas or electric?
-Bryan
Me, Wife, 3 daughters, and a woof woof
TV: 06 GMC 2500HD D/A SLT 4WD / Prodigy / Reese Signature 18K
FW: 07 KZ Durango 315BH / Fifth Airborne / Sidewinder / JT Strong Arm Stabilizers
DennisG9
United States
Posted: 04/25/10 10:09pm Link  |  Print  |  Notify Moderator
Had a neighbor move in with an 05 toy hauler with a Norcold not working. Did a search on line and found how to do a manual reset with 6 in of wire. Works fine now. Shop up the road quoted her $650+ and a local RV tech wanted $150 plus what ever parts needed just to look at it.
Got to love Google!
sirdrakejr
Las Vegas, Nevada
Posted: 04/25/10 10:52pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to tech issues.
Frank
2011 Palomino Maverick 1000SLLB on a 2004 Dodge Quadcab CTD Ram3500 SRW long bed equipped with Timbren springs, Stable Load bump stops, Rickson 19.5" wheels/"G" range tires and a Helwig "Big Wig" rear anti sway bar.
dougrainer
Carrolton, Texas
Posted: 04/26/10 05:54am Link  |  Print  |  Notify Moderator
You are new to the Forum. Please post Year and Brand and Model of RV when asking technical questions. Also post the Brand and Model of the appliance. You can't get accurate advice without this info. Are you positive it says C2 and NOT CO? Doug
Rob's
Home
Posted: 04/26/10 06:54am Link  |  Print  |  Notify Moderator
"C2" means freezer fin thermistor out of range. You could try to slide it up and down to see if it will go back into range.
The thermistor is a thermal resistor that changes resistance depending on its temperature. It clips onto the fins inside the refrigerator and communicates temperature changes to the appropriate circuit board by the change in its resistance. Normally when a thermistor goes bad it has a very high resistance and causes over cooling.
On Norcold models up to, but not including the 900 series model, the thermistor should have a reading of around 40,000 ohms between the terminals of the connector when the sensor end is place into a glass of ice water.
Rob
RV Tech
julie3872
georgia
Posted: 04/26/10 07:31am Link  |  Print  |  Notify Moderator
1997 Jayco
Norcold model 962
Thank you for replies.
dougrainer
Carrolton, Texas
Posted: 04/26/10 07:44am Link  |  Print  |  Notify Moderator
C2 on a 962 indicates AC Heater fault. The unit can still be operated on LP in the manual mode. The odds are the Element is bad. Doug
