Woodalls Open Roads Forum: General RVing Issues: Awning Blisters?!
 > Awning Blisters?!
Sheddah
Virginia is for Lovers
Posted: 05/23/10 08:35pm Link  |  Print  |  Notify Moderator
After I finished washing the awning on our MH this morning the sun came out to dry it.[emoticon] Once it was dry, I noticed quite a few blisters in the fabric. They were filled with air. (It appears that the fabric is actually made of two layers and in these spots they had separated.) This was the first time I noticed them. After I rolled up the awning and then let it down again the blisters had flattened. Has anyone else seen these? What would cause them and should we try to do anything about them?
DH and Me ">
2004 BT Cruiser 28 Ft
sayby1campers
Rock Hill,SC
Posted: 05/23/10 09:00pm Link  |  Print  |  Notify Moderator
I have the same issue... ny awning's getting old(03). I found some tears in the awning near the roof. I sealed them up with awning repair tape(Walmart) and all's well.
DW, DD(10y/o) and CoCo our Sharpei(wrinkle dog)
billyboy
md
Posted: 05/24/10 04:05am Link  |  Print  |  Notify Moderator
i have the same problem with mine and i saw it when it was brand new. the factory said to cut out a large section of it and send it to them or an a & e dealer and they would evaluate it for warranty which is 3 years. i was on a trip at m.b. and didn't want to not have it , so i didn't do anything, but they are still there 2 years later. i don't know if it will be a problem down the road.
08 33 windsport 22k towing 06 saturn ion
daytona7
Florida
Posted: 05/24/10 04:39am Link  |  Print  |  Notify Moderator
If there is a Pin Hole in the awning, instead of buying a whole roll of tape, request a sample from ETERNABOND. They send a 2 in. square sample in silver. OR, just go to your locla Post Office and get a small roll of Their Packing Tape. Have both on 2 pinholes for 3 years and still holding.
Homer
Northeast Indiana
Posted: 05/24/10 06:27am Link  |  Print  |  Notify Moderator
Yes I have had the problem and it never got any worse after several years. I was told to use a hypodermic needle and inject some water proof thinned out glue into the bubble. I never did that, but I think it would have worked.
JJBIRISH
Butler, PA, USA
Posted: 05/24/10 06:43am Link  |  Print  |  Notify Moderator
The separation will continue to grow and will eventually start to fill with water, and may even begin to peal…
It is a common problem that often goes unnoticed until it gets pretty bad…
They are two layers of vinyl laminated top and bottom to a nylon fabric…
I believe they are just using cheaper laminating processes and thinner vinyl then what they once did…
If it is under warranty considering the cost of repairs, don’t ignore it… they are well aware of the problem but will act as though yours is the first one they heard of… the material itself is covered for three years, but not the labor, unless you can convince they it should be a goodwill gesture…
Sheddah
Posted: 05/24/10 12:53pm Link  |  Print  |  Notify Moderator
Thanks everyone! Well the awning is 6-7 years old now, so I guess it's out of warranty. ;- ( I think you are right about the quality deterioration. My daughter has a 1996 with the original awning and has no blisters at all. Ours is a 2004. How many years should one expect an awning to last now days?
JJBIRISH
Butler, PA, USA
Posted: 05/24/10 02:56pm Link  |  Print  |  Notify Moderator
That seems about it for them today… my 91 has what I believe to have its original 24 foot fabric yet and is in good shape…
My 04 bought in 03 fabric started delaminating a couple years ago, and is trash now, but I use it year round to…
I was lucky and got a replacement fabric (not for free) real cheap form dometic as a good will gesture and will be installing it very soon…
USAFBILL
Alabama
Posted: 05/24/10 03:17pm Link  |  Print  |  Notify Moderator
Dometic told me mine was "delamination" of the material and they paid for a new awning and the labor. Now this was four years ago and the awning was 2 years old.
JJBIRISH
Butler, PA, USA
Posted: 05/24/10 04:48pm Link  |  Print  |  Notify Moderator
yep... the warranty is two years parts and labor and three years parts only...
 > Awning Blisters?!
