Woodalls Open Roads Forum: Toy Haulers: How to change tire on toyhauler
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers
 > How to change tire on toyhauler
SBrooks72
Phoenix, Az
Posted: 08/01/10 10:13pm Link  |  Print  |  Notify Moderator
Hey all, I have a rookie question. How do I change out my tire on my parked toyhauler? It is not hitched up to truck. It is sitting under my RV shed. Where do I put the jack? Should I put it under the frame closest to the bad tire? During detailing it after the last trip, I discovered a bad tire left rear tire. Probably from pivoting during my learning curve of backing it in off the street. Chewed it up pretty good.
* This post was edited 08/01/10 10:42pm by SBrooks72 *
markie mark
So Cal
Posted: 08/01/10 10:40pm Link  |  Print  |  Notify Moderator
Jack under the axle in question
06 F350 PSD CC FX4
06 Raptor 3612
00 YZ426, 02 YZ250, 02 KX85, 05 CRF70, 07 CRF50
06 Rhino 660
Member CORVA, AMA, ASA, BlueRibbon Coalition, AAPL
Norcalrockhunter
NORCAL
Posted: 08/01/10 10:42pm Link  |  Print  |  Notify Moderator
Just had a couple of tires off mine last week it was un hooked from the truck and it was in my driveway
I made sure that my tires were all chalked and I made sure that I had a jack stand ready to go, I jacked it right behind the tire on the axle and once the tire was free I put the jack stand right next to it lowered the jack but left it under the axle, another thing I did was to lossen the lug nuts while the tire was still on the ground
JIMNLIN
Oklahoma
Posted: 08/02/10 06:52am Link  |  Print  |  Notify Moderator
Good advise. I would add just make sure the jack is close the the axle U bolt or the U bolt itself on a standard leaf spring suspension. A torsion type suspension is another matter/problem.
'97 Park Avanue 28' 5er 11200 two slides
wild bill
Mira Loma, Ca. USA
Posted: 08/02/10 09:13am Link  |  Print  |  Notify Moderator
I have done it a couple of different ways.....jack under axle between spring u bolts for one tire removal....and while working on the suspension or to rotate tires I used a 5" wood block (cut from a 2x4 to fit frame width) directly behind the rear most spring hanger and lift all three wheels off the ground on one side....making sure that other side is blocked well...[emoticon]
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000, WEB SITE
http://home.earthlink.net/~wbrown02/wildbillwashere22/index.html
Macs Dad
SoCal
Posted: 08/02/10 05:17pm Link  |  Print  |  Notify Moderator
Or just hook it up to the truck and pull it a foot or two with a block under the other tire.
2007 Weekend Warrior SL2805
20505 Chevy 2500 HD Crew Cab 6.0/410 Gasser
2008 Polaris RZR 800 With +6 Long Travel
2012 Kawasaki KX 250F
1990 Kawasaki JS 550 Jet Ski
LowRyter
OKC
Posted: 08/02/10 06:28pm Link  |  Print  |  Notify Moderator
somebody had dropped some screws in my storage stall. Had two flats (of 4). Used a bottle jack under the axle. Worked fine. Tires still hold air despite the plugs.
BTW, why did Weekend Warrior add a spare and no jack?
Also, cheapo Harbor Freight 12v compressor works OK. But to keep it from blowing a fuse (60-70 lb of air), turn on the compressor BEFORE you connect the air hose to valve stem.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
dedmiston
Valencia
Posted: 08/02/10 07:19pm Link  |  Print  |  Notify Moderator
They told me it was for liability issues. Apparently wussie RV owners like us aren't qualified to change our own tires, so they want us to call in a pro to get it done.
I learned this the hard way when I flatted out at Dove Springs. I had to drive in to Inyokern to buy a lug wrench. That was in 2004 and I'm still bitter. [emoticon]
2014 RAM 3500 Diesel 4x4 Dually long bed. AISIN trans & 4.10 rear. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • Hooligan #3
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
The Edmistons
SBrooks72
Phoenix, Az
Posted: 08/03/10 11:59am Link  |  Print  |  Notify Moderator
Thanks guys, it worked out.3 ton jack under axle closest to the wheel as i could get. It will be easier to chg tire while hitched I am sure.
Brooks
HTElectrical
Las Vegas
Posted: 08/04/10 10:55pm Link  |  Print  |  Notify Moderator
If you read your Dexter manual, or any trailer axle manual, they state to NEVER place a jack under the axle or anywhere on the axle tube. You need to use the frame.
2007 Duramax, Cognito 7"-9" Lift,
