Woodalls Open Roads Forum: Travel Trailers: Low water pressure??
 > Low water pressure??
javaseuf
California's Gold Coast
Posted: 09/08/10 11:38am Link  |  Print  |  Notify Moderator
bigcampnut wrote:
Thanks again...... I'm beginning to believe its not my regulator. Last night i hooked up the water supply directly from my home with no regulator or filter in the line, and my pressure was as low as it was with them hooked up. So maybe I do have the restricters in each faucet and the shower head??
Yup!
bigcampnut
North Carolina
Posted: 09/08/10 10:54am Link  |  Print  |  Notify Moderator
javaseuf
Posted: 09/08/10 10:39am Link  |  Print  |  Notify Moderator
Many confuse low pressure with low flow rates.
Most likely your pressure is fine but the flow voluum from the faucets is low due to the flow restrictors every new faucet has in the aerator. I have removed mine and flow rate is much better.
Just be aware that more flow results in holding tanks filling faster.
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 09/08/10 03:33am Link  |  Print  |  Notify Moderator
Jimehc wrote:
Remove the 45 psi pressure regulator and flow restriction - your problem is solved..
Some kind of regulator should be used whether it's the 45 psi model or what ever. Some campgrounds have very high water pressure that can blow you're pipes out without one.
I visited a campground on Center Hill Lake in Tennessee this past winter and they had signs up warning about high water pressure. The campground was located very near a water tower and there must not have been any type of regulator on the thing. One of the Core of Engineer's employee's said he's seen a lot of people that ignore the signs and then they'll have water running out of their trailer doors in a very short while due to pipes being blown apart.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
Posted: 09/07/10 10:48am Link  |  Print  |  Notify Moderator
It MIGHT be too low depending on what water pressure your trailer is DESIGNED to handle. Most older units were set for a maximum of 40 PSI but newer ones often are designed for 60 PSI. It is also possible that your water FILTRATION system is bringing down your water pressure down. Why not remove the filter cartridge and give it a try and I bet you'll have a lot more pressure. May just need to purchase a higher volume filter.
Jayco254
Eastern Missouri
Posted: 09/07/10 11:04am Link  |  Print  |  Notify Moderator
I had the same problem, it was a clogged water filter, Put a new filter in and water prressure went back up to where it should be.
Tom, Kathy, Nikki, & Kelly
Pets: Lady - Texas Heeler, Dinger - Rhodesian Riidgeback Mix
2008 Ford Expedition Eddie Bauer 4x4 5.4 ci 3.73 gears
2008 Dodge Ram SLT Big Horn 4x4 5.7L Hemi 3.92 gears
2007 Jayco Jayfeather EXP 254
Husky W/D, P-3
HappyTrails2U2
Posted: 09/07/10 11:48am Link  |  Print  |  Notify Moderator
bigcampnut wrote:
Maybe an adjustable regulator that goes up to 55?
If it's not the water filter clogged up then what you probably need is an adjustable pressure regulator like the ones sold on line at The Water Filter Store that flow more volume than the elcheapo type of regulators that the RV dealerships and Walmart sell.
http://www.rvwaterfilterstore.com/PressureRegulators.htm
The Watts Adjustable 263A Regulator, 2" diameter 0-160 gauge, 4-4.5 gpm is the one I have. The Watts Model N55BG Adjustable Regulator, 1.5" diameter 0-160 gauge, 6-9 gpm is another one that's a little more expensive that is a good one.
You don't need much more pressure you just need more volume. I have mine set at 49 PSI and I'm getting plenty of water.
You also want to make sure that your water hose is not kinked or restricting the flow somehow to.
DavidP
Raleigh
Posted: 09/07/10 12:57pm Link  |  Print  |  Notify Moderator
I use the 263A as well. Huge improvement, well worth the money.
bigcampnut
North Carolina
Posted: 09/07/10 01:34pm Link  |  Print  |  Notify Moderator
Thanks...... the hose isn't kinked, and the water filter is actually a home filter that i adapted over with hose fittings... I've tried it without the filter and got the same low pressure results and the outside pressure was at the water source was high. I wondered if 45 psi was just too low.... its a 2010 model, where would I find the recommended psi limit for the camper? And your right, it is a cheapo regulator from an rv store.
Jimehc
Taylorsville, Kentucky
Posted: 09/07/10 03:49pm Link  |  Print  |  Notify Moderator
I am not sure where or how this 45 psi of water pressure limit was set..
But the water lines will dictate the usable water pressure with a bust rating of 180 to 300 psi..
Most water pumps will provide up to 65 psi before they stop cycling..
