mike brez
milford ct
On my 1994 PaceArrow it is located behind the breaker panel under the fridge.
1994 Pace Arrow 33L,454,P30
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
Jerry B
Lake of the Ozarks
I agree with Rich. It is mounted on the back of the power service panel.
Jerry B
Mobile Suites 36TK3
racer99
channahon
On my 1991 bounder the transfer switch was mounted to the back of the breaker panel-It is only about 4x4 and it will have the wires that go to the main on breaker box-then one to shore power and the other to genny power--easy fix but I marked all the wires anyhow because I had to wait a week for switch and I thought I might forget--after I fixed transfer switch I noticed that I had 156 volts coming off my genny so I had to replace the regulator on genny which also ended up being a piece of cake-Might be worth checking your voltage after you change transfer switch-If you have high voltage as I did you better change regulator before you run genny and screw something else up with high voltage--Hope this is helpful RICH
robatthelake
Vancouver Island
It should be inside that Drivers side rear Compartment where the shore Power Cord is stored!
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
pulsar
Lewisville, NC
Moved from Forum Technical Support.
1995brave
San Antonio, TX
Follow your shore power cable back into the RV, it should be the first box the cable goes into. If that is not it check on the back side of the breaker box.
ernerym
Salt LakeCity
Hello, I have a '91 Fleetwood Pace Arrow and I would like to know where is located the transfer switch. I do not have power in my RV when is plugged at the regular power, but when my ONAN 6.5 KW is running, everything works perfectly. I already slided out the braker box looking for the tranfer switch and I could not find it. Can somebody tell me where I can find it? and what would be other location for it?. Thanks
