Woodalls Open Roads Forum: Torque Specifications Caliper Brackets E350 / 450 Super Duty
 > Torque Specifications Caliper Brackets E350 / 450 Super Duty
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 11/18/10 12:01pm Link  |  Print  |  Notify Moderator
Replacing the front calipers on the Class C
The remanufactured calipers are supplied with brackets (Semi Loaded as they call them).
I need the Torque specification of the 2 bolts that hold the Brackets to the Spindles (NOT the slider bolts).
Also the torque value of the Banjo Nut (Brake hydraulic line to Caliper)
Vehicle:
2006 Ford E350 Super Duty Cutaway (should be the same as E450 Super Duty)
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
CloudDriver
New Jersey Shore
Posted: 11/18/10 08:21pm Link  |  Print  |  Notify Moderator
I have the following service info from Ford for our 2003 E450 Chassis:
Front brake hose to caliper flow bolt - 22-30 lb-ft
Caliper bleeder screws - 13-18 lb-ft
Caliper bolts - 16-30 lb-ft
Brake Caliper anchor plate bolts - 255 ft-lbs
No guarantee that your 2006 E350 is the same.
2003 Winnebago Minnie 24F - Ford E-450">
pcassidy111
California
Posted: 11/18/10 10:08pm Link  |  Print  |  Notify Moderator
From Ford for a 2006 E250-450, single rear wheel and dual rear wheel.
Brake caliper anchor plate (bracket) bolts 166 ft/lbs with blue loctite.
Caliper flow bolt (banjo bolt) 26 ft/lbs
Hub extender nuts 130 ft/lbs
These are also the specs for a 2003 E350.
Pete
DUNEBUGGYDOUG
SHELBY FOREST TN.
Posted: 11/18/10 10:11pm Link  |  Print  |  Notify Moderator
just tighten them down no big deal
Kamphiker
Posted: 11/19/10 05:32am Link  |  Print  |  Notify Moderator
Thanks for the replies. I pulled one side off last weekend, yes the bolts have Blue Loctite on them. Temporally I re-torqued it back to 140 Ft Lbs to get the MH back to the normal parking slot.
I have found over the many years of MY shade tree repairs with the limited lift & working space on a drive way, using proper Torque values prevent broken and/or stripped fasteners, rounded heads. Proper Torque also eliminates a cause of vibration. I use my impact tools to remove nuts/bolts, use hand tools to reinstall to final values.
