Woodalls Open Roads Forum: Travel Trailers: Special License Needed Over 10,000 lbs GVWR?
 > Special License Needed Over 10,000 lbs GVWR?
cookeze
Sacramento, CA
Posted: 12/06/10 11:39pm Link  |  Print  |  Notify Moderator
Which states require at special license to tow over 10,000 lbs GVWR? A Non-Commercial Class A is needed in California. Here's the wording. A Class C is a normal driver's license:
With a Class C License, with a vehicle weighing 4,000 lbs. or more unladen, you may tow a:
* trailer coach not exceeding 9,000 lbs. gross.
* trailer coach or 5th-wheel travel trailer under 10,000 lbs. GVWR when towing is not for compensation
* 5th-wheel travel trailer exceeding 10,000 lbs. but not exceeding 15,000 lbs. GVWR, when towing is not for compensation and with endorsement.
With a Noncommercial Class A License you may tow:
* travel trailers weighing over 10,000 lbs. GVWR, not used for hire.
* 5th-wheel travel trailers weighing over 15,000 lbs., not used for hire.
tomlang
Los Angeles area
Posted: 12/07/10 12:11am Link  |  Print  |  Notify Moderator
The states all have reciprocity laws, meaning if you license makes it legal for you to tow your rig in your home state (California), it is legal in all other states.
This only applies to the type of license, not to whether or not the type of trailer combination is legal. That part is not reciprocal.
Tom and Lynne
Tom is an Electronics Engineer, Lynne a retired teacher.
2003 Foretravel 38' U295
Bumpyroad
Virginia
Posted: 12/07/10 04:37am Link  |  Print  |  Notify Moderator
many states have a similar restriction on motorhomes over 26,000 lbs.
bumpy
docj
Fulltime--Home is where we park it
Posted: 12/07/10 05:34am Link  |  Print  |  Notify Moderator
For those states that do have additional requirements on licenses, does anyone know if the governing law would be YOUR home state's or the state in which the vehicle (or trailer) is titled? I happen to have a CDL Class B to comply with Maryland law, but our rig is titled in Montana in preparation for going full-time. Montana doesn't have a requirement to hold more than the regular Class C. Which state's laws apply?
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
Posted: 12/07/10 05:47am Link  |  Print  |  Notify Moderator
Your OWN states laws are the only ones you need be concerned with. If you're legal at home you're legal everywhere. Unfortunately, California is one of the MOST picky states concerning RV use so you will probably actually exceed the needs for most states you'll travel through. the basic premise remains the same however. Legal at home means legal anywhere.
JoeGood988
S.Dakota
Posted: 12/07/10 07:03am Link  |  Print  |  Notify Moderator
"Legal in your home state means legal anywhere" Not true!! Just because you can pull a boat trailer behind your fifth wheel in Kansas doesn't make it legal in Eastern states...illegal in almost all Eastern States. Some states you can ride in the trailer going down the road....other states it's illegal....always check to see the laws.
2003 3330 Jayco Legacy
jmtandem
western nevada
Posted: 12/07/10 08:37am Link  |  Print  |  Notify Moderator
Nevada. 10,000+ gvwr TT or FW requires an endorsement on the normal drivers license.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
hotpepperkid
Kingman AZ
Posted: 12/07/10 08:51am Link  |  Print  |  Notify Moderator
IF the other states alow doubles towing some do and some dont (boat behind 5er ect) and your lic in KS alows it you can do it in other states also
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
tempforce
Oregun Pacific Wonderland (in the summers)
Posted: 12/07/10 09:08am Link  |  Print  |  Notify Moderator
as for the license, states will comply with issuing state. but as far as doubles, trailer behing a 5th wheel. does not transfer, you can only haul passingers in a trailer in states that allow it, same for doubles. if you violate local laws, it's at your expense...
just like obeying the local speed limits.
also as a precaution, check the manufactures fine print for your trailer tires. as some are only rated for a max of 65 mph.... i only found this out while shopping for new tires.... i was just lucky with the old ones, as i'm upgrading the tires this time...
happy trails, keep the shiny sides up...
somewhere in the texas 'lost pines'
currently without rv.
'13' Ford Fusion
'83' Ford Ranger with a 2.2 Diesel.
'56' Ford F100, 4.6 32 valve v8, crown vic front suspension.
downsizing from a 1 ton diesel and a 32' trailer, to a 19-21' trailer for the '56'.
Less Stuff
WA. USA
Posted: 12/07/10 09:14am Link  |  Print  |  Notify Moderator
Washington state exempts RV drivers from needing a CDL.
"Recreational vehicle (RV) operators are exempt when driving an RV for non-commercial purposes. This exemption includes 2-axle rental trucks and horse trailers."
Washington State
DG
Former user name: "Lots of Stuff"
2015 RAM 1500 V6 8 speed
Regular cab short bed 2 wheel drive.
Leer 180 Topper
