Woodalls Open Roads Forum: Travel Trailers: Two new small trailers coming for 2011
 > Two new small trailers coming for 2011
BroncosFan
USA
Posted: 04/22/11 05:17pm Link  |  Print  |  Notify Moderator
Two new small trailer upstart companies coming.
Google images "LiL Snoozy RV" for interiors shots of one.
Then, the other one is http://www.parkliner.com/
Tiger4x4RV
Inland Empire, Southern California
Posted: 04/22/11 06:11pm Link  |  Print  |  Notify Moderator
http://www.lilsnoozy.com/
(not much info on this link; the above method of searching Google images does turn up a few images from fiberglassrv.com)
jspringator
Versailles, KY 40383
Posted: 04/22/11 06:32pm Link  |  Print  |  Notify Moderator
I really like the Park Liner. How do they compare to Casita and Scamp? The bathroom layout was pretty cool.
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel
DesertHawk
Las Cruces, New Mexico
Posted: 04/22/11 10:33pm Link  |  Print  |  Notify Moderator
Very neat eggs.
Very similar to Casita & Scamps, with some differences:
Very clean lines, seems roomy, and no rivets (not like Scamp or Casita), but no toilet........Porta-Pot slides away for easy showering.
Not very large fresh water tank.......12 gal fresh water tank
Large grey water tank.....21 gal greywater tank vented to roof
5 gal blackwater tank...I assume part of the Porta-Pot
Has a electric shower pump like Scamps...to transfer shower water to greywater tank.
Two piece fiberglass body (seems the same)
Fiberglass cabinets with recessed cabinet doors
Plywood underlayment treated with marine spar urethane for moisture resistance (like Scamp, not Casita)
Cabinet doors made of ultra-light/strong marine plywood (seems the same)
Interior Length: 12' (17' Casita, maybe 14', not sure, but Scamp 16' is 13')
Interior Height: 6' 5" (taller than both Scamp and Casita)
Interior Width: 6' 7" (Overall width: 6' 8" for Scamp & Casita; Scamp Interior width: 6' 6"; Casita ? assume 6' 6")
Overall Length: 15?; Overall width: 6? 8?
Sleeps Four; Queen bed for two, optional bunk for two more, possibly more on floor (much better bed than Scamp, not sure about Casita)
Astro-foil insulation covered with special fuzzy wall lining to keep you warm or cool (just like Scamp, but not Casita)
Body Mounted AC Unit (does not clutter camper top); optional AC unit retracts through the trailer side when not in use.....an unique feature
Base Model – $13,500
Options Package – $15,250 but a toilet is not one of them.
A long discussion on them at FiberglassRV.com.
* This post was last edited 04/23/11 12:10am by DesertHawk *   View edit history
">DesertHawk- Las Cruces, NM USA
*2015 Lance 1985~Casita de Campo~23' 4" Tongue to Bumper, Dinette Slide
160 watt Solar Panel/GoPower! Solar Controller
*2009 White Ford F-150 Reg. Cab
Long Bed with A.R.E. Molded Fiberglass Topper
*Previously~ 2005 16' Scamp
rexlion
Broken Arrow OK
Posted: 05/07/11 09:06pm Link  |  Print  |  Notify Moderator
The Lil Snoozy will have the same fiberglass underside as the top and sides... more like Casita than like Scamp. Interior flooring can be vinyl or laminate.
Mike G.
--currently in between trailers--
To every thing there is a season, and a time to every purpose under the heaven... (Ecclesiastes 3)
retiredtraveler
Woodstock Il --- GO HIKING!!!!
Posted: 04/27/11 06:26am Link  |  Print  |  Notify Moderator
I like that Parkliner. It looks like they've listened to the criticisms people have about trailer design and done something about it.
Pup: Just donated Jayco1206 to a good cause
--- looking at Viking or Clipper pup for the Spring, 54w solar panel
TV: 2015 Hyundai Santa Fe
25 years tent camping, 4000+ miles of hiking in National Parks, lots of biking
