Woodalls Open Roads Forum: Travel Trailers: Installed 30A RV recepticle at the homestead
 > Installed 30A RV recepticle at the homestead
txtaco
Richmond, Texas
Posted: 06/05/11 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Today I spent 5 hours installing a 30A RV recepticle on the house... no more loading the trailer with it being 100+ degrees. For approx. $150 dollars, this was the ticket... I highly recomend for others to do the same.
* This post was edited 06/05/11 07:40pm by txtaco *
2004 GMC 2500HD CC 6.0/4.10 4x4
2008 Jayco G2 32BHDS
Pro-Pride Hitch
DWolfrom
Lena, IL
Posted: 06/05/11 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
I'm jealous...I've got everything I need to do it, just haven't had the time yet!!
2011 Keystone Passport 2590BH
2008 Chevy Silverado 1500 Z71 Extended Cab
WDH+Friction Bars
Prodigy BC
Bulldog #4000 Tongue Jack
Sean Boburk
I had a local guy do mine as a side job. I had a welder plug at the front of my garage that was broken and I would never use. He tapped into one leg of that (was two 30 amp breakers tied together) and put a junction box in so he could extend the wiring to where I wanted it, on the outside of my garage. Installed a box, plug, even had him install a motion light inside my garage. All for $100. Like you said, well worth it.
2011 Flagstaff 29SKBS
2010 F-150 4x4 5.4L
2011 camping days=23 in 9 locations
2012 camping days=2 in 1 locations
Gale Hawkins
Murray, KY
Posted: 06/05/11 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you got it done. It is a one time cost might still be working fine 25 years from now.
othertonka
Stockton, CA
Posted: 06/05/11 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going to do this please make sure you understand the basics of RV electrical systems. The 30 amp is 110 V AC, not a 220 V AC like some old dryer outlets were wired. Here is a link that shows how to do it.
RV 30 Amp
When the site comes up, click on 30 amp on the upper left side of the web site.
Better to be safe than sorry.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
md2lgyk
WV
Posted: 06/06/11 08:42am Link  |  Quote  |  Print  |  Notify Moderator
You spent $150? For what? I put one on a post 50 feet from the house for far less.
"The great object is, that every man be armed. Everyone who is able may have a gun." - Patrick Henry
aquarious
Marion Indiana
Posted: 06/06/11 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I installed a dedicated 30 amp 120 volt outlet on the outside wall of my garage. It cost me less than $100.00 because I am electrically savy enough to do it myself. It would cost considerably more if a qualified electrician is reqired. Ed
txtaco
Richmond, Texas
Posted: 06/06/11 09:41am Link  |  Quote  |  Print  |  Notify Moderator
$30 for the box w/ RV recepticle
$40 for the 12g wire
$45 for the conduit and fasteners (and other related stuff)
$30 for the 30A breaker
Had to run it from the back of the house to out front...
Bucky Badger
Madison, WI
Posted: 06/06/11 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Darn, I just bought a breaker for under 6 bucks..You got robbed there
* This post was edited 06/07/11 03:05pm by an administrator/moderator *
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
and
2009 Nomad 3980
wmoses
Houston, Texas, USA
Posted: 06/06/11 10:31am Link  |  Quote  |  Print  |  Notify Moderator
When I bring the RV home I plug it into the regular household AC and all seems well. The AC cools as normal also. I have never had it running the AC and the fridge at the same time, whcih is what I assume you will be doing when you mention "loading the trailer".
Next house mod for you is a sewer connection in the ground ... unless you already have one. Some use the waste macerator so that they can dump in the closest toilet. That might be cheaper and is mobile.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
