Woodalls Open Roads Forum: Travel Trailers: wood under tires
 > wood under tires
nhshep
New Hampshire
Posted: 07/05/11 06:51am Link  |  Quote  |  Print  |  Notify Moderator
decided to put our trailer on a seasonal site July 6 to July 6 2012. great rates nice location we like with lots activities. The site is gravel not concrete slab. Question, should we put down two one inch boards (1x12x4) under the tires, or would it not matter sitting on gravel for that long a time.
When the trailer was in Storage it was on tar hardtop, we never put anything under the tires. This time it's gravel, seasonal includes winter storage parked on the same site.
thanks...
jdgreen42
Silsbee, TX 77656
Posted: 07/05/11 07:02am Link  |  Quote  |  Print  |  Notify Moderator
I think if I were going to be there that long, I would put a treated 2x12 under them.
Don
Don
bldrbuck
one or the other
Posted: 07/05/11 07:03am Link  |  Quote  |  Print  |  Notify Moderator
It will be O'k on the gravel. With the price of wood you can probably go out for a hamburger by not using the wood.
justntime
Shunk PA.
Posted: 07/05/11 07:15am Link  |  Quote  |  Print  |  Notify Moderator
If you have any question at all in your mind about it I would put the wood down If I did not put the wood down and was thinking about it I would wonder and wonder till i gave in and done it My 2 cents The wood is cheap I would put camper on wood
DW79 DS07 DS10 Me77
2011 Zinger 26BL
Live Well Love Much Laugh Often
Techie
Pahrump, NV, USA
Posted: 07/05/11 07:39am Link  |  Quote  |  Print  |  Notify Moderator
For that long of a period I would put treated wood underneath.
2011 Airstream Classic Limited 34'
2011 GMC Sierra 2500HD Duramax/Allison SRW
Follow our adventures
clearnetedm
Alberta
Posted: 07/05/11 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure about the wood but when we store our trailer for the winter in the gravel lot we never use wood. However if I was going to use the trailer parked for that long I'd be looking at maybe blocking up the suspension better than just the stabilizer jacks. Also if you have a slide you might look at blocking it up if it's intended to stay out the entire time.
2008 Ford Expy EL
2012 Rockwood 2601S
B.O. Plenty
Minnesota
Posted: 07/05/11 08:16am Link  |  Quote  |  Print  |  Notify Moderator
My last park trailer sat on the same seasonal site for 10 years on gravel. I checked the tire pressure and aired them up every year, that's all. New owners towed it away on the same tires..no problems. I would have been pretty nervous doing that but the guy they hired to move it said he rarely had problems...
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Just say no to Chinese tires.
Cylinder count: 27, down from 51
Twin Cities Mn.
Rickj91
Penticton, B.C.
Posted: 07/05/11 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Have had a seasonal site for the past 11 years, taking the trailer out whenever we need to. have always used wood under the tires. Our temperatures go from +100F to -20F. Never have a problem. thus I recommend wood.
nhshep
New Hampshire
Posted: 07/05/11 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I think we will put the wood down under the tires plus put the tire covers on and check the air pressure once in a while. Thanks for the advice.
p.s.
I read jacking up to relieve weight on axels if not done correct can cause problems. I don't plan to redistribute any weight off the wheels and tongue jack.
HappyTrails2U2
Atlanta, GA & Augusta, GA
Posted: 07/05/11 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I don't think most people will go along with putting a jack under the slides. You won't find that in the owners manual either. The slides are designed to be out without jacks and if the tires were to go down on that side while a jack is under the slide it will push the slide up to where it would probably tear something up.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
 > wood under tires
