Woodalls Open Roads Forum: Dinghy Towing: Geo Tracker flat towing
Search only in Dinghy Towing
 > Geo Tracker flat towing
wciim
Woodruff, SC
Posted: 08/12/11 02:40am Link  |  Print  |  Notify Moderator
We found a Geo Tracker 1997, 74K miles in perfect condition. It is automatic 4x4. We wanted to tow 4 down. Have we messed up? Does anyone out there tow an automatic 4x4 tracker 4 down? If so, is there a need for any mods? Have there been any problems?
Bumpyroad
Virginia
Posted: 08/12/11 03:45am Link  |  Print  |  Notify Moderator
I "think" you did mess up. I towed a mid 90s tracker 5 speed stick shift which at that time needed the manual front hubs to tow it. I am sure at the time that I would have bought an automatic if it was towable. now you can modify with drive shaft disconnects/tranny pumps etc. when buying a vehicle, always look in the owner's manual under recreational towing or towing behind a motorhome and see what they say, just because somebody comes on and sez "I towed mine 2,000 miles and it was OK" means nothing to me, the tranny could go out in 48 thousand miles instead of 148,000.
bumpy
gbopp
The Keystone State
Posted: 08/12/11 05:04am Link  |  Print  |  Notify Moderator
Did you check the Remco Towing Application Charts?
PapPappy
Wilmington, NC
Posted: 08/12/11 05:35am Link  |  Print  |  Notify Moderator
Yeah, looks as if Bumpy is right.....you bought the wrong year.....I went to the site (above) and they said this:
1989 - 1998 Geo Tracker
Engine:ALL
Drivetrain:2WD
Transmission:Automatic
Click here to tow your 1989 - 1998 2WD ALL Geo Tracker
Application Notes
Stub kit only. Waiver must be signed before shipment. $658.00 for parts to modify existing drive shaft.
It appears the newer ones could be towed without any modifications.....sorry[emoticon]
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau ">
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.">
Purchased April 2008"> FMCA# F407293
The Pets
D.E.Bishop
Eagle Rock, CA
Posted: 08/12/11 06:00am Link  |  Print  |  Notify Moderator
I went to the above site and all that is needed is MANUAL HUBS. It is a 4X4 w/Auto. I tow a 95 sidekick all the time and have no problems. I think Bumpy and Pap Pappy must have read the wrong thing in the original post. If you need help determining if you have auto or manual hubs, just PM me I'll send info and photos. It is a great towed.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
06 Suzuki Grand Vitara 4X4
Stowmaster 5000
randco
Somewhere in time
Posted: 08/12/11 06:22am Link  |  Print  |  Notify Moderator
sbishop is correct. I also checked Remco and the site has to following information for the 4WD model.
Drivetrain: 4WD
Transmission: Manual/Automatic
Towable as is with manual hubs. Aftermarket manual hubs available.
I think I would listen and get help from sbishop.
PapPappy
Wilmington, NC
Posted: 08/12/11 06:58am Link  |  Print  |  Notify Moderator
I stand corrected.....hey, it's early in the morning[emoticon]
I looked at the 2WD version....sorry.
enblethen
Moses Lake, WA
You need about manual or automatic hubs and then you are good to go. You can verify which if any hubs you have. Look closely at the front hubs. If they require turning you have manual, if they say automatic, you are good to go. If they have a plate with bulge in center, you need hubs installed.
Put transfer case in neutral, Transmission in PARK. Book says to stop every 250 miles or so and run engine with transmission in Drive for five minutes. I run in drive and then operate for couple minutes in reverse also.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
2003 Chev Ice Road Tracker
zigzagrv
Nazareth, PA
Posted: 08/12/11 07:10am Link  |  Print  |  Notify Moderator
Been towing a 95 Tracker, auto, 4wd w/auto hubs for 5 years and 40k plus miles and NO problems. Good find!!
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
tworootless
Wher ever
Posted: 08/12/11 08:40am Link  |  Print  |  Notify Moderator
We also purchased an old Auto trans Tracker with Auto Hubs. You can flat tow once the hubs are replaced to manual hubs and the vehicle is placed in free wheel or neutral.
