Woodalls Open Roads Forum: Truck Campers: Insulation and Condensation in winter
Search only in Truck Campers
 > Insulation and Condensation in winter
BruceWayneandTrishaJ
Missouri
Posted: 10/20/11 09:32am Link  |  Print  |  Notify Moderator
We lived in our Big Foot truck camper last winter - it was our first time to winterize - wrap pipes - etc. I read someone's suggestion to put bags of insulation at the sides and in the bed of the truck. Is it that simple? Is there a simple way to do this between the roof of the truck and the camper's sleeping area? I need explicit directions - this is all new to me.
Also, the problem that was most frustrating last year was the condensation under the mattress. Any ideas how to add breathing room there to prevent the build up of moisture and mildew? We have a memory foam mattress on top of regular 3 inch foam.
Thanks for whatever tips and tricks you have to share.
Bruce and Trisha Barnes
We love our life!
Find us on Facebook!
narcodog
Georgia
Posted: 10/20/11 09:56am Link  |  Print  |  Notify Moderator
Under my mattress I added some beard board type of insulation then I took Reflectic's (sic) and made a tub around the walls. I attached the Reflectix to the wall with 3M removable strips so I could remove them if I wanted. They have been on there for four years. I also attached foil backed duct insulation to the escape hatch. The kind that is sticky on one side. I also put that on the inside of all of my cabinets.
sabconsulting
High Wycombe, UK
Posted: 10/20/11 01:12pm Link  |  Print  |  Notify Moderator
I've not had a problem with condensation under the mattress. But we did have a problem with it being cold, so I've cut a piece of spare carpet and put that under the mattress.
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'98 Jeep TJ 4.0
'15 Ford Fiesta ST
'10 Citroen DS3 1.6 turbo
louiskathy
Oregon (presently)
Posted: 10/20/11 06:12pm Link  |  Print  |  Notify Moderator
I've laid two sleeping pads under our mattress..the thicker fold up kind...not the backpack roll up kind. We have an electric blanket we keep on during the day so the blankets and mattress are kept warm..helps to warm the entire camper.
Switched to micro fleece sheets and blankets...better than flannel.
And when we bought a new mattress for the class A...I cut the pillow top off of the old mattress and put it on top of the truck camper mattress.
Kathy
narcodog
Georgia
Posted: 10/21/11 07:26am Link  |  Print  |  Notify Moderator
There is a marine material that is sold for boats that you can put under your mattress. I don't remember what it is called but look at West Marine they may have it.
Bubtoofat
SE Michigan
Posted: 10/20/11 07:23pm Link  |  Print  |  Notify Moderator
Reflectix. Slept down to 5 degrees F with NO condensation or frost anymore.
2005 Chevy 2500HD Crew 4X4 6.0
2011 Northstar Adventurer
Hellwig Bigwig, Ride-Rites, Fastguns, KYB Monomax.
"No matter where I am, I can't help feeling I'm just a day away from where I want to be."
Jackson Browne - Your Bright Baby Blues.
Chief 2
Florida
Posted: 10/21/11 04:54am Link  |  Print  |  Notify Moderator
How has everyone been dealing with the condensation that builds up on the walls and ceiling from just breathing? Some mornings we wake up and have water beaded up on the ceiling joists and in the corners of the walls.
2005 Lance 1181 Loaded
2005 Chevy 3500 4X4 Duramax, Edge Attitude Tuner, 5" Exhaust, Airaid, Ranchos, Air Bags, Hellwig Big Wig
2007 38RL3 Mobile Suite
2001 Bass Tracker 185
kohldad
Goose Creek, SC
Posted: 10/21/11 05:20am Link  |  Print  |  Notify Moderator
You will need to leave an upper vent cracked to allow a little fresh air to flow through the camper. This will help pull the moisture out of the unit.
When you cook, you may want to crack a window and open the roof vent a bit more to create a little more draft to remove the extra moisture from the food.
If you are stationary, you may want to consider a small dehumidifier, though in a TC, room to set it could be a problem.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hc avg mpg after 16,500 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Gary3
Windsor, ON
Posted: 10/21/11 07:13am Link  |  Print  |  Notify Moderator
Last winter we had some nights that were in the low 20,s and I left the window on my side cracked open and one vent open a little,very little condensation if any at all. The window stays the same until we packup and leave.
Gary  Lance  1191 solar Gen.
nelson
Clio,Mi USA
Posted: 10/21/11 07:19am Link  |  Print  |  Notify Moderator
Condensation is a common problem, Showering and Cooking add a lot of moisture. You can crack a vent to let some of it out along with your heat. Insulate or add air space under your mattress or even find a small dehumidifier if you have the space.
