jims1
NC
Roger10378 wrote: I wouldn't but the truck that way. No one recommends towing with a new truck. It needs some break in miles before towing.
I'm not looking to start anything here, but with the modern diesels. There is no "Break in ".
Cummins for example Dynos each engine before shipping. Cold engine- fuel it- start- wide open throttle for several minutes- shut down.
My last truck I actually pulled a boat I was delivering to the dealer, swapped my hitch over, hooked up to the new, and ran for Florida.. It got a 1100 mile Break In
If you ever get a chance to tour a Cummins Factory, its impressive.
'06 Ram with a Cummins
Tuned w/ EFI-Live by Rich at DogHouse Diesel
'96 532 CarriLite
Me, Alie, and Salie
laknox
Arizona
jims1 wrote: Roger10378 wrote: I wouldn't but the truck that way. No one recommends towing with a new truck. It needs some break in miles before towing.
Too bad they put 'em in Dodges. (GD&RLH!)
Lyle
2002 GMC Sierra 2500 HD Duramax Crew Cab 4x4
Banks Bullet Tuner and Monster Exhaust
B&W Turnover Ball with 5th Wheel Companion
2004 Komfort 25FSG Fifth Wheel
1936 John Deere Model A
International Flying Farmers 50 Year Member
Byrogie
Okotoks
Clarification...I only meant to pick up the trailer at the factory.
Truck will be purchased wherever I find the best deal...will fly many miles to save $$$$$
I also, would like that link to major truck deals in Utah
Cheers
colliehauler
Mc Pherson KS USA
If you ever get a chance to tour a Cummins Factory, its impressive. In my owners manual it said to put 500 miles on before towing, not because of the motor but to seat the rear end gears.
bigdon68
Churchville, Maryland
Check out all of the truck manufacturers and you will find that Ford is the toughest performer out there and can haul more than any of the other manufacturers. As far as SRW or DRW I like the single rear wheel. A 1-ton truck is a 1-ton truck. The single rear wheel give you a lot more flexibility driving around after you unhook.
I have been towing a 40ft. 5th wheel for 5 years now with no problem. Good luck with you decision. Take you time and check it out --- that's what I did.
Take care.
Bigdon68
2008 F350 CC 2WD LB 6.4 Lariat Auto SRW, Retrax, AirSafe Hitch, CB, Train Horns, On-Board air, RideRites, Aux Tank
2007 Ameri-Camp SummitRidge Reserve,40ft, Onan, MorRyde IS, Disc Brakes,17.5 Alcoa Wheels, Michelins, dual AC, Bigfoot Levelers
My Pictures
a_flyfisher
PA and MT
Newmar has (or at least had one the last time I knew) a factory pickup program, but there is an extra charge for it. It was around $1,000 - $1,500 the last time I heard. I understand they spend as much time as needed going over everything with you, and you can get any required fixes made before leaving the factory.
When we bought our Newmar Kountry Aire in 2008, I had heard about the factory pickup program, but I opted to take delivery at the dealer instead. If I had to do it over, I would take delivery at the factory in a heartbeat. I would want to stay in the area in my RV for at least 1-2 weeks though to make sure everthing is working OK though before I left for home.
a_flyfisher
USA in a Chevrolet
Manahawkin, New Jersey
USA in a Chevrolet wrote: Golden_HVAC wrote: It would help to know what state you are in, and if you want to pick it up before the spring thaw, and if you want to drive through 2 feet of snow to a northern factory or not. Not much fun to pick one up in Ohio in the winter, then TRY camping on the way back home to Idaho.
There are some truck sales places in Utah that offer great internet truck pricing, and they already know how to register your new truck in your home state, get the sales tax paid, and forms filled out.
At least if you get a quote from them for say $39,595 for a dually diesel, and you go to your local dealership who says the sticker says $55,575, and I can't go a penny lower than $52,995! Anything less and I will be loosing money! you know it is a song and dance.
Good luck picking out the RV of your dreams, and the truck too! It helps to pick out both at the same time, so you don't say buy a 3/4 ton truck then find out that the fifth wheel is 11,000 pounds with a 2,200 pound hitch weight, and the truck you just bought will not handle that much hitch weight!
You might pick one out that is wonderful, then see a Montana fifth wheel with the fireplace, dual recliners, and is 15,500 pounds with a 3,100 pound hitch weight once loaded and ready to go. That might take a special truck, 3500 dually or F-350 single rear wheel truck with a 4,100 pound cargo rating.
Remember that ALL manufactures weight are just suggestions, and that loaded weight will be a lot more than the DRY weight on one trailer built last year with no options then taken to a scale.
And that when GMC says "You can tow a 14,500 pound fifth wheel with a 2500 truck" they mean that very rare and difficult to find fifth wheel with a 1,000 pound hitch weight, so that you can still take along the grandkids, and wife. Most fifth wheels have 25% of the trailer's overall weight on the hitch pin, that can be into the 2,500 - 3,300 pound range with some trailers. Difficult enough for a 1 ton truck to handle, some will require a daul rear wheel truck.
Whatever you do. next thing is to get a towing brochure from the big three. It will explain the GVWR, GAWR, GCVWR and list the weight ratings of the various trucks in the lineup. You will notice that most trucks when you get the supercab, or crewcab, the cargo rating goes down. Same with a 450 pound diesel engine option. That truck with a 2,500 pound cargo rating is a regular cab gas engine model, 2 WD, not with the 400 pound 4 wheel drive option, or 400 pound crewcab option.
Once you narrow it down, post the prostective truck and trailer. Someone who owns that brand might chime in and say they had problems or good things to say about that brand. I know a guy with a Cedar Creek, and he has wonderful things to say about his brand.
He also has a air ride hitch, and says that is a great thing too, keeps the trailer from bouncing so much.
Fred.
Can you give me the name of one of these truck dealers where I can get a truck with a $55975 MSRP for $39,595? I would be very surprised if you are serious about these numbers! Remember, I am asking if there is a place to buy a $55,000 MSRP truck for $40,000. That would be 28% off the MSRP!
Still Waiting!
cruz-in
UAS
Just drove to from the northern indiana factories from Maryland). No problems with snow....only saw a little on the ground...warm winter so far.
lar5camping
Rocky Mountains
If your factory pickup is a Toyota Tundra. Sell it!
Dave & Ginny
peoria, IL
Byrogie wrote: Yes, the combination of truck and trailer is important. Have already decided that the truck will be a one ton diesel, only decision left there is single or dually. That decision will be made when we find the right trailer.
We live in Alberta, so much research to do.....
This is probably a 2 or 3 year project, and will be timed for the summer.
I had narrowed my truck search down to a dodge or ford. I went with the F350 because I didn't want a dually and the Ford could carry more hitch weight. I bought the truck 8 months ago and have put over 26000 miles on it so far and I think it's the best truck I've ever owned.
I found the Redwood 5er and my truck are matched perfectly with each other. I have one on order now and I should have it within a month.
Good luck with your search, I'm glad mines over
