Woodalls Open Roads Forum: Tow Vehicles: Check Coolant Level
Search only in Tow Vehicles
 > Check Coolant Level
RLGetman
On the Road - MS 5er
Posted: 02/01/12 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
New Ford 450 6.7 T. Computer says "Check Coolant Level - OK" I checked the coolant level and it was fine. The engine temp has not increased either. l am wondering if I have a bad sensor and input.
othertonka
Stockton, CA
Posted: 02/01/12 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
The coolant level sensor might be in the overflow tank, don't know that for a fact, but just a guess. Worth a look, could just be wires disconnected from the sensors.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Executive
California/Arizona/South Dakota
Posted: 02/02/12 01:07am Link  |  Quote  |  Print  |  Notify Moderator
Loose or broken wire....Dennis
Dennis and Debi
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
Chevy HHR W/ ReadyBrute
Full Timing and Living the Dream
Farmer David
Mattoon, ILL.
Posted: 02/02/12 03:58am Link  |  Quote  |  Print  |  Notify Moderator
That light came on on my truck a couple weeks ago I took it to a dealer I was out in Arizona at the time and they said it has to do with the acidity of the coolant, they want it at a certain level. So they took it into the shop and checked it and told me it was OK and reset warming light. The bummer was they charged me $32 to do that
2011 F350 DRW Super Cab Lariat Long Box
60 Gal RDS Tank
18K SS Reese Hitch
09 Cameo 34CK3
gmcsmoke
Butler
Posted: 02/02/12 04:49am Link  |  Quote  |  Print  |  Notify Moderator
New means you have a warranty. Use it.
Old-Biscuit
Across the USA
Posted: 02/02/12 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Had the same on my 07 RAM.......'low coolant' warning.
Visual check......looked OK/Normal
Added a little coolant to overflow and warning went away....
fordsooperdooty
Posted: 02/02/12 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
You can clear the trouble code by disconnecting the battery terminal for a few minutes, and re-connecting. If it returns, seek the dealers help.
My posts shouldn't be taken for factual data. They are purely fictional, for entertainment purposes and should not be constituted as actually related to scientific, technical, engineering, legal, spiritual or practical advice. Amen.
RLGetman
Posted: 02/02/12 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone
RLGetman
Posted: 02/09/12 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
FYI - Stopped at Ford Dealer in Harlingen, TX. They said this "Check Coolant Additive" message is a "reoccurring" warning that simply reminds you to get your coolant tested. They used a test tab similar to a pH test strip and said "everything is good" I asked how often it is not good and they said they have never had the test fail. If is did, they would flush and refill. Both the test strip and coolant are only available through Ford (I am told). Thanks
45Ricochet
North Idaho
Posted: 02/09/12 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah the Ford dealer also says trucks are only available at Ford too
Me thinks auto part stores jusssst might carry something that would work also.
06 Dodge 3500 CC LB Laramie 4x4 Dually 5.9 Cummins 325/610 48RE Jacobs brake Smarty Jr
GVWR 12,200 Payload 4580
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C
27' Hallett 502, 500HP
