mikeleblanc413
Sour Lake, Texas
I've seen some differing opinions. Our new to us Winnie is a 2000 and this is something that probably should be checked. I'm wondering what is the worst case scenario if I don't check it and do they REALLY work?
All input appreciated. In East Texas IT'S WET...but it's still a great day!
Mike LeBlanc
Retired Educator, Texas Certified Art EC-12, Professional Photographer
Sour Lake, Texas
Facebook
Flicker
2000 Minnie Winnie DL, 429U, V10,
Cooper ATR, Bilstein HD Shocks, Steer Safe,
TireMan, Pressure Pro TPMS, EMS-PT 30C,
SportRack Bicycle Rack
harold1946
Surprise Arizona
The worst case scenario would be a rusted out tank. Normaly the anode will last 3-4 years but I check it annualy when doing routine maintenance. It also helps to keep minerals from building up on the electric heating element and reducing its efficiency.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
pianotuna
Regina, SK, Canada
Hi Mike,
Yes, they really work.
Regards, Don
mikeleblanc413
Sour Lake, Texas
Is this an item that can be cleaned and reused or does it need to be replaced?
THANKS!
pianotuna
Regina, SK, Canada
Hi Mike,
The anode material erodes over time. I'd replace it with a new one and monitor the loss of material on a yearly basis. Rate of loss depends on how many minerals are in the water supply. Where I live my house hold water heater anode needs replacement about every 18 months.
abc40kids
Dale City,Virginia
I replace mine every year and it usually needs it.
Jeff,Julie,Amber,Brandon,and Casey,Dexter(Golden),Bruno(Pug)
Forest River Cardinal 362bhs 2006
2005 Chevy duramax dually 4x4 crew cab,Ultra Goliath wheels with Nitto Dura Grapplers and Banks exhaust.
chuggs
Florida
Whenever there are disimilar metals, and moisture...galvanic action takes place. It will consume the least noble metal. That's why sacrificial anodes are used. They get eaten away...so you cannot refurbish or clean one...it has to be replaced.
I'm guessing you would rather spend $12 on an anode than $225-$500 on a new RV water heater??
I replaced the rod in my home water heater about a year ago. My water heater is WAY past it's warranty date...and will probably last a very long time if I keep up with replacing the anode in it every 5 years or so.
downtheroad
Pacific Northwest
Chump change maintenance.
Less than 5 minutes to check and change...$12 bucks.
The water heater should be drained anyway before storage and removing the rod is how the tank is drained.
GMC Duramax/Allison (LBZ)
Reese Dual Cam HP
bukhrn
Lanexa, Va
YES, they do work, Are they needed, that depends, if you have an ATWOOD Heater, then NO you don't need an Anode Rod, (although they do make a rod for them) just something drain your wallet for no reason. If you have a Suburban water heater, you better have an Anode Rod, as was said, way cheaper than buying a new heater.
2007 Forester 2941DS
2005 KIA Spectra
Zamboni, Long Haired Mini Dachshund
You can have my RV, when you pry my cold dead fingers from the Steering Wheel
Our Pics
bukhrn
Lanexa, Va
New One & One ready for replacement
http://www.google.com/products/catalog?q=rv+anode+rod&rls=com.microsoft n-us:IE-SearchBox&oe=UTF-8&rlz=1I7GGLL_en&um=1&ie=UTF-8&tbm=shop&cid=1110946375985091229&sa=X&ei=FKAuT6TOK-OJsQKL6oyiDg&ved=0CFQQ8gIwAw#
