Woodalls Open Roads Forum: Class C Motorhomes: Do Anode Rods REALLY work?
 > Do Anode Rods REALLY work?
mikeleblanc413
Sour Lake, Texas
Posted: 02/05/12 09:30am Link  |  Quote  |  Print  |  Notify Moderator
THANKS bukhrn!!!! Now I know what to look for when I open mine for a possible change.
Have a GREAT day!!!!
Mike LeBlanc
Retired Educator, Texas Certified Art EC-12, Professional Photographer
Sour Lake, Texas
Facebook
Flicker
2000 Minnie Winnie DL, 429U, V10,
Cooper ATR, Bilstein HD Shocks, Steer Safe,
TireMan, Pressure Pro TPMS, EMS-PT 30C,
SportRack Bicycle Rack
PenMan
New Mexico
Posted: 02/05/12 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
You can always test the theory. Don't replace it and it could cost thousands. The tank rusts out and then water leaks everywhere for who knows how long. It's cheap and easy maintenance.
Chris and Jane and two boys (and a DDIL) who prefer tents
2007 Rockwood Roo 23B
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
Posted: 02/05/12 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
You won't find any ship at sea that doesn't use the principal. Yes they do work. Every time I've ever removed one I find it eaten nearly in half close to the connection to the plug and that's electrolysis it SAVED my water tank.
Handbasket
Asheville, NC
Posted: 02/05/12 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yep... _not_ needed for Atwoods. Essential for Suburbans. I don't recommend the aftermarkets ones with the little radiator-type drain cock in the center, either. First, you really ought to flush the crud out of the WH when you drain it, and second, the drain keeps a regular 1 1/16" socket from engaging the hex.
Jim, "Recession: Just like recess, but longer. And no snacks."
Dusty R
Charlotte Michigan 48813
Posted: 02/05/12 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2003 Itasca. It has an Atwoods which is an aluminum tank, no anode rod nor is one needed.
A lot depends on the water. In our stick house I installed a new water heater more than 30 years ago. I removed the anode rod when I installed it, because in our area within a couple of years an anode rod will make the hot water smell like rotten eggs. We also have a water softener.
Dusty
tatest
Oklahoma Green Country
Posted: 02/09/12 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think Winnebago uses the Suburban water heater. It should be Atwood, with an aluminum tank and no anode.
The anodes do work, where they are needed, and that would be a porcelain-lined steel tank water heater. As soon as the porcelain cracks, the tank will start rusting unless there is a sacrificial anode to corrode instead.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
mikeleblanc413
Sour Lake, Texas
Posted: 02/09/12 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
You're right...I do have an Atwood...so...don't need to worry about the anode...THANKS for your input! We're off in the morning for a long week-end with friends and giving "mouth to mouth" to some wine! My wish is that your week-end is just as GREAT!!!!
mowermech
Billings, MT
Posted: 02/09/12 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
"Do Anode Rods REALLY work?"
IMO, YES, they DO!
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, 5 speed, 4.10 LS diff., Jacobs Rambrake, 275,000 Miles
'95 Tioga 29H Ford-based Class C
Daily driver: 2005 Jeep Grand Cherokee Hemi
Toad: 2006 Jeep Rubicon LJ
sonicsix
Jerry n' Cynthia
Posted: 02/10/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
New anode rod, old anode rod. I prefer the anode rod to look like this, not the inside of my water heater tank.
Full Time RVing Blog -- RV Mods and Upgrades -- http://RVnumber.com?1
2004 Gulf Stream 6236 24' Class C towing a 1999 Jeep Cherokee 4x4
