Woodalls Open Roads Forum: Dinghy Towing: Dolly towing backwards
Search only in Dinghy Towing
 > Dolly towing backwards
Gale Hawkins
Murray, KY
Posted: 02/05/12 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
SoCalDesertRider wrote:
It has been done before. You will need to tie off the steering wheel so the front tires remain straight. Tow trucks lift rear wheel drive cars by the rear axle all the time to tow them away. Pretty sure there's no law against towing a car backwards, even here in California, where there is a law against just about everything.
2X
SoCalDesertRider
SanDiego, CA, USA
Posted: 02/05/12 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
johntichy wrote:
Thank you. I have an old BMW wagon that is the perfect car for my dog once I settle in at an RV resort. Will be pulling it with a 40' American Eagle. Planning on going from FL to WI for the summer. After 23-years, I had enough of the FL summer heat.
For that long of a distance, I would use a flatbed trailer to haul the car, or put it on the dolly forward and disconnect the rear driveshaft and tie it up, or tow it on a tow bar with the driveshaft disconnected. For just a cross-town trip, hauling backwards on the dolly would be fine. Like I say, tow truck drivers pull cars that way all the time in the city, but they don't take them several states away by that method.
05E350 6.0PSD
97F350DRW 7.3PSD 4x4 4.10 11' flatbed
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
fatmanobx
Russellville, Ar. Home Base
Posted: 02/05/12 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have towed both ways without anyproblem. I had a F150 that I towed 2k miles backwards and never had a problem of any kind. No weaving, wear on front tires, nothing. I droped the driveshaft one time and pulled it forwards and there was no difference until i had to lay under it and put the driveshaft back in during a rain storm..I have also towed a Ranger pickup backwards without any problem at all. They both towed stright and no weaving..This was behind a 37' Class A...If it is straped down properly and tight you should not have any problem with it....
2003 Four Winds Infinity 37'
2000 Tracker TC
3.5# Minpin named Darcy
Ford F250 Super Duty
just me
Salt Lake City Utah USA
Posted: 02/05/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Load it and have someone follow you and see how it handles and see if the tires wiggle wildly. Check for unusual wear. And then check the lug nuts they have a tendency to loosen up going back wards. On Semi-tractors they tow them backward all the time. When they hit the yard thats one of the first things that gets attention.
95 Dodge CC #5 TST plate Flame Red/Silver
not totaly stock
2007 fiver
Tag Ma-haul has been suggested for a name but now The Shoe box
whisperide
Golden Spike area
Posted: 02/06/12 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Best to just disconnect the driveshaft, for the above reasons and 3 more. Firstly, it's not difficult to undo the driveshaft from the differential, I can do it in half an hour. Second, you don't want to risk ripping the airdam off the nose of the car, and third, the rear of the car has a better departure angle.
Another option is to trade yours in on one with a manual transmission, so there won't be any need to disconnect the driveshaft.
'06 GMC C2500HD RCLB gasser 4.10:1, 4L80E, custom camshaft
'84 Trans Am 6.2 diesel, 700R-4, custom Class-3 receiver
'69 F350 dually. GM 6.2 diesel, turbo, 700R-4, NP208 all pending.
Texas Bohunk
Highlands, Texas
Posted: 02/13/12 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Wreckers tow backwards all the time with no problems. While this is not the best way, I have towed my 2005 Durango backwards a couple thousand miles. No problems so far. Just make sure the steering wheel is locked / secured.
s79vette
Twin Lake.Mi.USA
Posted: 02/13/12 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Our camping neighbors tow their fairly new Ford PU with a topper to Biloxi every year with no problems, backwards. They are now staying in the Moose Lodge campground and it's a red Ford if you want to talk to them.
2003 Gulfstream Ultra Supreme Ford V10 2004 Jeep Liberty, Blue Ox, Brake Buddy
Online with Inspiron
A member of http://www.gsowners.com
Gale Hawkins
Murray, KY
Posted: 02/13/12 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
Most do not know how to do it correctly so it is easier to just tell them it can not be done.
Number two most are towing FWD stuff so it is a non issue.
