Woodalls Open Roads Forum: General RVing Issues: Stackable vs. combo washer dryer
 > Stackable vs. combo washer dryer
Sarasotawhitedog
Frederick MD
Posted: 02/05/12 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I am considering purchasing a new fifth wheel and will be installing a washer /dryer.
I saw there is a RV Splendide XC Extra Capacity Combo Washer Dryer available. It washes up to 15 lbs in one load.
How well do these combos really work?
Is it worth the space saved?
Anyone used a combo and a stackable? Thoughts?
Not so concerned with cost as I am efficiency and ease of use.
docj
Fulltime--Home is where we park it
Posted: 02/05/12 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
We have the unvented Splendide combo and love it. Sure, it would be nice to dry the clothes a bit faster, but it's sure better than not having it. As for the combo vs stackables, we like the huge closet area above the washer. A stackable would take up all that space; we wouldn't want to lose the storage space. Furthermore, it's very nice to be able to put dirty clothes in and get clean dry ones out a few hours later.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Follow our adventures on Facebook at Weiss Travels
pulsar
Lewisville, NC
Posted: 02/05/12 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
mayo30
Lanigan
Posted: 02/05/12 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Never had one or the other what happens to the moisture from an unvented dryer?
Sarasotawhitedog
Frederick MD
Posted: 02/05/12 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
The 'unvented' dryer air goes into the water drain and into the grey tank from what I understand.
Ivylog
Blairsville, Ga. USA
Posted: 02/05/12 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
If money and room is not an issue then sure get the stacked. I would only get a non vented as a last resort as they use a lot more water. The extra water is used to cool the drum so the moisture condinsates and is pumped out. We use our 2100 combo a lot and do not see the need for stacked units as our works well. You learn to hang some things out to dry speeding up the dry cycle.
Where am I?
How I tow.
beemerphile1
I'm only 57, I'm not yet a
Posted: 02/05/12 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I'm interested in this as well. We will be getting our full time retirement rig soon. My uneducated thoughts are;
Combo - can only do one load at a time but may save some space and weight.
Stackable - may use more space and may have more weight but can be drying one load while washing another.
Tim
If you aren't paranoid, you aren't paying attention!
2006 Weekend Warrior FK1900 towed by 1998 Ford E150 4.6L = 8 MPG
2009 Aliner Sport towed by 2009 Pontiac Vibe 1.8L = 22 MPG
1996 BMW R1100GS
Sarasotawhitedog
Frederick MD
Posted: 02/05/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Ivylog: If I am in a park with good water and pressure....why would amount of water used be an issue/concern? The RV dealer, whom I respect and trust is an advocate of the combo unit.
imgoin4it
Alamogordo, NM USA
Posted: 02/05/12 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Have had a splendide vented unit and it was OK. Small loads and wrinkled clothes. Traveling friends had an unvented unit and did about the same job but took much longer to dry. They said they would never have another unvented one. We now both have stacked units and would never go back to a combo. Works just like "at home". If you have the room go for the stacked unit
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
slickest1
canada
Posted: 02/05/12 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Our coach has a splendide combo and it was vented to the outside right from the factory, the same as a house. DW loves it and wouldn't be without. The loads are smaller and the dry cycle takes longer. We added an stackable dryer that we found at an rv parts store that was taken out of a new unit. It took some extra space but DW is happy so everyone is happy!
2000 H.R. Imperial 38wds rr8r roadmaster, isc 350 cummins
2007 Chevy Trailblazer, Blue ox towbar
Ready Brake with breakaway.
