Woodalls Open Roads Forum: 2005 toyota tacoma long bed 4x4 jayco 264hh
 > 2005 toyota tacoma long bed 4x4 jayco 264hh
Page of 6
dlclarkee
new york
Posted: 02/06/12 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
have 2005 toyota tacoma long bed 4x4 6500 tow capacity with factory tow package buying jaco 264bh 2012 max weight loaded is 6500 only pulling mostly flat roads 45 miles to beach and back did not have up grade on leaf springs done is it going to be ok to pull this trailer with this truck? thanks
donn0128
Pronounced Ore-gun
Posted: 02/06/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
NO!
Seriously, what motor? What transmission?
Your biggest problem is going to be wind resistance. It takes a lot of horse power to move that brick wall down the road at legal speeds. And you will not have it.
Donn,Lorri,Max (rescued Lab)
dlclarkee
new york
Posted: 02/06/12 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
6 cyl people in other wed sites say they have tow this, wd anti sway equipment tranny is one that came with truck has tranny cooler weight of trailer empty is 4500
DarnJoe
Home
I wouldn't do it!
dlclarkee
new york
Posted: 02/06/12 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
iam sorry but iam not getting this the truck is rated for 6500 as long as i keep the weight of the trailer under 6500 why will it not work driving on flat roads the dealer is of course saying it is not going to be a problem of course they want to sell a trailer
Quick trip
Cerritos, Ca.
Posted: 02/06/12 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
You are not just talking of the weight of the trailer.
Once you add propane, batteries, food, water & all your other stuff you will have added anywhere between 500-1,000 lbs more!
You say you can pull this trailer with no problems, BUT can you stop it in an emergency?
Good Luck & Drive Safe!
bikendan
Napa, Cal.
Posted: 02/07/12 01:48am Link  |  Quote  |  Print  |  Notify Moderator
you got to be kidding me, a nearly 30' trailer with a Tacoma!
plus the actual hitch weight will be over the Taco's max.
it'll be at least 650-700lbs.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
amxpress
Clayton, NC
Posted: 02/07/12 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Yes, you can tow it, providing you don't load the TT down too much.
Your Tacoma has a Class IV hitch. With a WD hitch, the max capacity is 1,200#. Don't think you'll be anywhere near that.
Keep the weight down on the TT.
NOW, you won't break any speed records and you'll need a good brake controler. You won't be going up any mountains and big hills will be a challenge. You will know the TT is back there.
Keep it on level ground and keep the TT's weight down.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
Ron3rd
Upland, CA USA
Posted: 02/07/12 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it will pull it, but you won't like the result. Your trailer is almost identical to mine in weight, which I pulled with my first Gen 2000 Tundra with the 4.7 V8. It was "ok" on the flats but slow on the hills. That truck was "rated" to tow 7100 lbs, was bigger and more powerful than your Tacoma and it felt like it really had its hands full and was right at its towing limit. You can probably get away with it for short trips over flat land but forget about taking that setup any long distance.
2007 Tundra SR5 CrewMax 5.7 V8
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
dlclarkee
new york
Posted: 02/07/12 08:13am Link  |  Quote  |  Print  |  Notify Moderator
thanks all for advice not going up any hills mostly flat roads only 45 miles each direction only it is interesting to see different opinions just want to make sure before i do this
Page of 6
