Wrace
Seattle WA
Wondering what you all use to clean the lcd tv and monitors, as well as things like camera lens, scanner glass, etc?
I've never had much luck with the 'wipes' and much prefer the solution and cloth to be separate. The only thing the big box electronics stores seem to carry anymore are the wipes so I'll have to order something from Amazon or elsewhere.
I'll try and check the owners manuals of this stuff around here for guidance as well, but was wondering if there is some generally safe options for use on these type of devices?
Fizz
Ottawa, Canada
Got mine at Walmart.
It's called Phillip's Screen Cleaning Gel for plasma and LCD.
A spray bottle with a small soft cloth.
Works great.
Old-Biscuit
Across the USA
I use two micro-fiber cloths.
Damp one to remove dust etc. and then a final wipe with clean dry one.
TV, monitor, camera, phone etc. haven't had any problem YET
BB_TX
McKinney, Texas
Fizz wrote: Got mine at Walmart.
Works great.
x2
Maxi Signal
Buffalo , NY
I use a great product called IClean , it is made for just what you are describing . You can get it online from a company called The Advantage.
Wrace wrote: Wondering what you all use to clean the lcd tv and monitors, as well as things like camera lens, scanner glass, etc?
john b
anywhere USA!
I have had excellent luck with using the pull out wipes I got at office supply. Slick & easy & good job done! JMHO jb
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
jorbill2or
Oregon
Just plain water on a soft cloth .. I can't believe you would need anything else nor is anything else recommended. Tell the grand kinds to keep there hands off the screen! ;-)
It should only need dusting it your not touching it!
My post's are my opinion The advice, comments etc are free and worth what you paid
Bill
lzasitko
Regina, SK Canada
I use a product called lKlear. One has an alcohol base and the other is basically a dry lint free cloth. Not sure what else is in it but it really works good but is also a little pricey. Each is in a sealed package.
MrWizard
Van Nuys, Ca
100% clear denatured alcohol cut 50-50 with distilled water
I keep a little squeeze bottle ready,
dust with clean cloth wipe with another clean cloth dampen with this mix
No scented rubbing alcohol, no window / glass cleaners
no chemicals besides distilled water and denatured alcohol
used to be available at the drug store, I bought mine at home depot in a pint/16oz can
Options, always have options, and the journey goes much smoother
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
Member of the Verizon Wireless Customer Council
I BOUGHTthis phone
therink
Rochester
I use Windex. Never any problems.
Steve Rinker
Rochester, NY
2010 Keystone Outback Sydney 329fbh 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
