Woodalls Open Roads Forum: Revived Trailer Tire Thread (formerly on the 5th Wheel Forum
 > Revived Trailer Tire Thread (formerly on the 5th Wheel Forum
Page of 89
CapriRacer
Somewhere in the US
Posted: 02/09/12 11:04am Link  |  Quote  |  Print  |  Notify Moderator
just me wrote:
Butyl rubber then being a synthetic compound and is used inside the tires for better air retention, and can with stand the elements better then regular rubber, is also used on the outside of ST's' also to protect against the elements and sidewall/weathering, or checking and being a proper/better application than the rubber used for LT's. Course they are now using more SILICA in the manufacturing process now. And I guess this helps in many ways.
Am I right in this assumption? Or not. This has not been brought up that I could see.
Thanks again. Very informative
First the obligatory warning. I am not a chemist. I know a bit about the subject as it applies to tires, but I am - as the phrase goes - a "dangerous man" because of how little I know.
So lt me put it like this. Absolutely, butyl rubber is used inside the tire for its air retention properties.
But, no, it is not used on the outside of tires because it's basically incompatible with the types of rubber that work well in tires. In fact, our factories have very strict isolation procedures to prevent the cross contamination of butyl rubber with anything else.
Silica's main benefit is that it alters the Treadwear/Traction (especially wet traction)/Rolling Resistance technology triangle that exists for tread rubber. By adding a little silica in place of carbon black - and adjusting the recipe a bit - you can improve the rolling resistance and not hurt the other 2 properties. However, there is an upper limit to the amount of silica that can be used before you run out of ability to adjust the formula.
CapriRacer
Visit my web site: www.BarrysTireTech.com
CapriRacer
Somewhere in the US
Posted: 02/09/12 11:09am Link  |  Quote  |  Print  |  Notify Moderator
ExRocketScientist wrote:
My interpretation of your response to Francesa is that you are saying if one replaced failing ST tires with truly comparable LT tires, they would likely have just as many problems with the LT tires.....
That is what I am saying - but the caveat is that there is hardly any situation where they are truly comparable - and there lies the rub.
......It is interesting to note that frequently when members here seek advice on replacements, they get anecdotal evidence from people who either switched to LT tires or Maxxis ST tires. What you see at the end of the thread is that they have followed suit, however, they have also at the same time chosen a tire with a higher load capacity. I would suspect that the others who provided anecdotal evidence of their choice solving their problems may have done the same (myself included). It may all boil down to your advice (that also comes from FastEagle and several other members here with many miles of towing experience) that you really need to select tires that will give you a 15% margin over your GAWR regardless of whether it is an LT tire made in the USA, or an unheard of brand of ST tire made in China.
And I will jump on that bandwagon, too! I think going up in tire size will pay more benefits than anything else.
CapriRacer
Somewhere in the US
Posted: 02/09/12 11:22am Link  |  Quote  |  Print  |  Notify Moderator
My read from the 700+ page document I linked earlier is that they use either carbon black or silica as the filler in tires. The interesting thing is the effect these material have on the coefficient of static friction and the coefficient of sliding friction. For those of you who aren't physicist like me -- a quick explanation. The coefficient of static friction (when you are not sliding) is higher than that of sliding friction. Once your force along the surface exceeds what the friction force can counteract, you start sliding. Once you start sliding, there is less friction, so things aren't getting better. So you don't want to start sliding to begin with. So enter into the picture anti-lock brakes. The idea of these braking systems is to take you to the point just shy of starting to slide. So in theory, with antilock brakes, you never experience sliding friction. Well tires with silica have a higher coefficient of static friction than those filled with carbon black. There are also differences in the coefficient of sliding friction. But what is more important is that the coefficient of sliding friction actually decreases the more you slide. The problem with the silica filled tires is it decreases at a faster rate than those filled with carbon black.
So on a vehicle with antilock brakes you want silica filled tires; on all other vehicles you want carbon black filled tires.
Trailers don't have antilock brake systems, however, you have an adjustment on your brake controller. If you are good at adjusting it for your weight and the current road conditions, you can get braking relative to your tow vehicle braking that approaches the performance of antilock brakes and would benefit from silica filled tires. On some trailers, you just can't get the brakes to lock, so you would also benefit from silica filled tires. But for those of us who are not that good at the adjustment and can manage to lock the trailer brakes in a panic stop, the carbon black filled tires are a better choice.
The problems is -- when looking at a particular tire, how do you know what it is filled with?
I am going to thoroughly disagree.
First, tires don't behave according to classical friction theory (Amonton's Laws of Friction) in that the maximum force is generated when the tire is slipping 10% to 15%. That's because the road surface has texture and the rubber penetrates that surface and tearing off bits of this rubber can generate more force than friction alone predicts. That's why I use the word "Grip" to describe the property of interest.
So it doesn't matter if the tire has silica or not, the ABS system is trying to provide wheel slippage in the range mentioned.
But as I mentioned in the post above, there is a technology triangle and you can have extremely slippery tires with great rolling resistance that have silica.
And lastly, there is no way I know of to tell if the rubber compound has siloica or not, unless you are told - and it would be a bad assumption to assume it isn't there unless you have specific knowledge to the contrary.
CapriRacer
Somewhere in the US
Posted: 02/09/12 11:36am Link  |  Quote  |  Print  |  Notify Moderator
OK . . . I think I've been a little slow the past few days. It's the K factor!.......So if I got that right . . . I can take it to the next level. The service conditions for trailers are not understood correctly so the K factor for ST tires is wrong.......
That is an argueable point. It could also be argued that far too many trailers overload the tire. The situation is terribly unclear.
.......The trend in the industry has been to go to bigger and bigger units with more gadgets in them. Perhaps the TRA needs to revisit the K factor......
or perhaps the trailer industry needs to size the tires to cover those differences. After all that's what car manufacturers do.
But, again, the situation is terribly unclear.
RandACampin
Kathleen, Georgia
Posted: 02/09/12 11:37am Link  |  Quote  |  Print  |  Notify Moderator
CapriRacer wrote:
But I will tell you that I see an awful lot of LT tires used in trailer service with failures - and there is one more item that I can't reveal so you'll have to trust me on this - when aI do apples to apples comparisons, I don't see a difference.
Hmmm...very very interesting!
* This post was edited 02/09/12 11:43am by RandACampin *
ausie607
white lake
Thanks again CapriRacer and couple of other contributing members!!!!
I learned two things about RV tires;
1. They indeed are round, black, may contain rubber and 'other squishy stuff'
2. Seriously, the threads refocused my observations and thought process to loads , margins etc. that was brought to light in this thread. I spent most of last night using that approach searching the net with stellar results. Learned lots.
Thanks again, feel free to step up to the podium any time, REALLY!!!
Dwight
Chris
Shelter Bay, Wa
Posted: 02/09/12 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have been saying for a number of years to not leave the dealers lot on inferior tires. No one else seems to be assuring that trailers have decent tires, so buyers should be looking at more than the glitter and bling.
However intended use plays into it. If you are going 10 miles to the lake and back once a year then minimal tires might be OK. If one wants to see America, then you need good tires for a safe and comfortable trip.
Chris
My Rig
2005 Cardinal 29WBLX.
Francesca Knowles
Port Hadlock, Washington
Posted: 02/09/12 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Dear CapriRacer,
As a presumed industry insider, can you explain the difference(es) in
A) Performance between bias-ply and radial (trailer) tires, especially as it relates to rolling resistance?
And
B) Tread depth/pattern, also as it affects rolling resistance?
Please do differentiate between single- and double- axle trailers if per your understanding any differences exist.
Thanks!
* This post was edited 02/09/12 06:51pm by Francesca Knowles *
FastEagle
Taylors, SC
Posted: 02/09/12 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Chris wrote:
kedanie wrote:
Let me see if I understand correctly.
You say that an ST tire needs a 15% reserve and should not be loaded beyond 85% of sidewall capacity. Also, you indicate that the LT tire can be used at 100% of it's sidewall capacity.
If this is true, then a lot of manufacturers of RV's are doing their customers a disservice by putting underrated tires on their vehicles. One that comes to mind is JAYCO that still installs 16" load range "D" ST tires with a 3000# load capacity on rigs with 6K axles. Don't believe me? Go to your nearest dealer and take a look.
Keith
Or most Montana's with GAWR OF 6750 and tires rated to 3420. Do the math 90 full pounds of extra capacity per axle. Chris
The RV show at the Jacksonville, FL Equestrian Center opened today. It was also half price day for seniors so we drove out for a look see.
Here is one that confirms none of the major heavy fiver trailer manufacturer's give a hoot about reserve load capacity in their OE tire selection.
Here is a picture of a vehicle tire placard. It’s self explanatory.
Tire Placard
The nice clean tires were easy to read. Goodyear Marathons
rated at 3420# at 80 psi. Isn’t that just GREAT?
FastEagle
p.s. This one was not much better but it did have a little higher rated tire at 3520# at 80 psi.
Tire Placard
* This post was edited 02/09/12 07:36pm by FastEagle *
Chris
Shelter Bay, Wa
Posted: 02/09/12 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Keith
Tire Placard
FastEagle
FastEagle how do we get consumers and manufacturers to wake up?
60 minutes seems to gotten Congress attention on insider trading! Anyone know someone on 60 minutes staff.
I can see it now Barry our new buddy on 60 minutes!!! Chris
Page of 89
