jarozi
Houston, TX
I created a spreadsheet as part of my research for our first TT. I'm looking primarily at models with a bunk house room and at least one slide. Figured I would share the sheet in case anyone found it interesting. Let me know if you see an bunk house room model I haven't considered. I am assuming a conservative 20% transfer of tongue weight to trailer axles in my TW calculation, per various posts on the subject.
Link to RV Spreadsheet
I'm not real familiar with Google docs, but I think if you want a copy you can muck with, choose "file->make a copy". Your truck capacities can be set on the second sheet. As currently composed it's using the capacities for my F-150.
Thanks!
edited 02/08/12 01:41pm by jarozi *
traydon
West Winfield NY
you should check out keystone cougar 321 sqb
2008 Ford F-250 CC V-10
2007 Chevy Tahoe
2011 Keystone Cougar 31 SQB
lpxguy
Chalfont PA
wow very cool! you may want to check out our bunkhouse: Flagstaff 831KDSS (Forest River), I can tell you pretty much anything you need to know
2010 Silverado 2500HD 4.10 gas hog
2011 Flagstaff 831KDSS 31' TT
14,300 lbs, 55' long
Wxguru
Austin,AR
We have a 2011 Cherokee Grey Wolf Bunkhouse. It is the 28A+KS model. Best feature is....2 slides....back slide has double bunk on bottom and single on top...and their own cable hookup for the kids
It is a Forest River product. 5700lbs and some change dry weight.
2011 Cherokee Grey Wolf 28A+KS
2003 Dodge Ram Quad Cab 4X2, 5.7L HEMI, 3.55 gear ratio
KZ'ers
Iowa
We have the KZ Spree 321bhs and just love it... Have had not problems in first year of owning it...
2009 FORD F-250 FX4 6.8L TRITON V10
2011 KZ Spree 321BHS
afob3
Maryville, TN
Neato... Your list could get rather large if you add everyone's suggestions but I'll throw mine in there too.
4200 actual dry. 5700ish gvw
www.koalarv.com
2012 Koala 25DS
2011 F150 Ecoboost SuperCrew with Max Tow Package
www.familyobrien.net
Lowsuv
Oregon
Nice work.
Where I come from we call your type a " Slide Rule'r" .
That is a good thing !
MOREDLEG
Missouri
U DA MAN, this is one cool spreadsheet.
Here is mine
Keystone Hornet 31RDBS, 8500 lbs dry,
Alan
2006 Dodge 3500 Quad Cab 4X4 5.9 CTD
2011 Keystone Hornet 31RDBS
MOREDLEG
Missouri
Here is mine
Alan
jarozi
Houston, TX
Thanks for all the recommendations, I've updated the list with all the full width bunk house models. Thanks again!
