Woodalls Open Roads Forum: Fifth-Wheels: Camper drain pipe question
Search only in Fifth-Wheels
 > Camper drain pipe question
Chevyman2006
Georgia
Posted: 02/08/12 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I want to re-do my drain pipe and dump valve for the kitchen grey water tank.
Attached is a picture of the current setup. To drain the tank, I have to get down under the slide to reach the handle.
I want to just move the dump valve down just before the junction, making it more accessible. The pipe appears to be 2" OD. Can I use regular PVC pipe or where can I get this black pipe and a few fittings?
Thanks in advance!!
2006 Chevrolet 2500HD 4wd CC/SB Duramax/ Allison
2005 Forest River Flagstaff model 8528bhss 30' 5th Wheel
2002 Coachmen "Spirit of America" 248TB (SOLD)
Wife and two BEAUTIFUL girls!!
Nights camped in 2010: 64
Nights camped in 2011: 58
agesilaus
North Florida
Posted: 02/08/12 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
It's ABS pipe, you can get it at Home Depot ect.
Glendale Titanium 29E34TS fifth wheel
2012 Ford F-350 4WD Lariat 6.7L
PullRite OE Series Super5th 18K
Chevyman2006
Georgia
Posted: 02/08/12 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, thanks!!
I actually looked for it at my local hardware...but they looked at my like I had two heads.
Chevyman2006
Georgia
Posted: 02/08/12 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Here is an overall picture as well.
Peg Leg
Anderson, IN
Posted: 02/08/12 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
If you leave some of the pipe on each side of the valve you can reuse the valve by putting a coupling on each side of it.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker
Yamaha EF3000iSE
retired gadgetman
bad99ram
home
Posted: 02/08/12 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
They make a transition glue that you can go from ABS to PVC. I found it at Lowes.
K Charles
Connecticut
Posted: 02/08/12 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
You can get a cable to put on the waste valve handle.
eHoefler
ozark mountains
Posted: 02/08/12 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
ABS and PVC pipe are the same size dimensionally and can be used together in any combination. You will need to use universal cement to glue them together.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
45Ricochet
North Idaho
Posted: 02/08/12 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Your good to go, I was just wondering what those two 2x10's were for? Did it come stock that way or are my eyes playing tricks on me
06 Dodge 3500 CC LB Laramie 4x4 Dually 5.9 Cummins 325/610 48RE Jacobs brake Smarty Jr
GVWR 12,200 Payload 4580
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C
27' Hallett 502, 500HP
ScottG
Bothell Wa.
Posted: 02/08/12 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
What you propose is exactly what they did on mine plus, you get a little bit more capacity (maybe 1/2 gal).
Scott, Grace and Wesly
H0NDA eu2000i
