Woodalls Open Roads Forum: Fifth-Wheels: Camper drain pipe question
Search only in Fifth-Wheels
 > Camper drain pipe question
Old-Biscuit
Across the USA
Posted: 02/08/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Chevyman2006 wrote:
agesilaus wrote:
It's ABS pipe, you can get it at Home Depot ect.
Ok, thanks!!
I actually looked for it at my local hardware...but they looked at my like I had two heads.
Must not be much of a hardware store.
ABS pipe is common...used in residential homes, commercial buildings etc.
Use ABS pipe, fittings and get ABS glue.......your new valve will be ABS and so will the slip-glue flanges you will need.
Chevyman2006
Georgia
Posted: 02/08/12 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
rick83864 wrote:
Your good to go, I was just wondering what those two 2x10's were for? Did it come stock that way or are my eyes playing tricks on me
My camper developed a soft spot in the floor around the heat register.
I removed the underbelly and found that the floor consisted of very thin plywood over about 3" of foam board.
I installed those PT 2X6's from one side to the other, both front and rear of the register. I then cut a 24X24" of 3/4" plywood to go between the top of the new "joists" and bottom of foam board. I cut a 3X10" slot for heat register and remounted it.
Now its solid as a rock!!
2006 Chevrolet 2500HD 4wd CC/SB Duramax/ Allison
2005 Forest River Flagstaff model 8528bhss 30' 5th Wheel
2002 Coachmen "Spirit of America" 248TB (SOLD)
Wife and two BEAUTIFUL girls!!
Nights camped in 2010: 64
Nights camped in 2011: 58
TugCE
Leesburg, Florida
Posted: 02/09/12 02:42am Link  |  Quote  |  Print  |  Notify Moderator
What about using one of those valves that is made to connect just like the dump hose? They are usually used when the main valves leak but I would think you could put one on the discharge pipe and then just leave to main valve open. This is what I am going to do for my galley tank and the valve is a pain in the butt to get to.
05 Chevy 2500 4x4 D/A with Helper Springs and Air Ride Air Bags
06 R-Vision RW3360 Fifth Wheel Toy Hauler
97 FLTCI converted into a Roadsmith Trike by The Trike Shop of Daytona
Lantley
Ellicott City, Maryland
Posted: 02/09/12 04:22am Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Chevyman2006 wrote:
Ok, thanks!!
ABS is not readily available everywhere. You do not see it in MD. PVC is the pipe readily available here. I imagine it varies by region.
07 Duramax Crew Cab Dually
2012 Open Range 399BHS
Trailersaver BD3,Blue Ox Bedsaver
air bags w/compressor
Prodigy,Splendide W/D,TomTom
Arvika pin box bike rack
14'Porta Bote w/9.9 Johnson outboard
5500 Onan Propane genset,Vu Cube 2000
Retrax tonneau cover
rattleNsmoke
Western Conn.
Posted: 02/09/12 05:07am Link  |  Quote  |  Print  |  Notify Moderator
How are you going to support the new valve? I think you're going to have to strap the pipe real tight so it won't shift each time you open\close the valve.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
45Ricochet
North Idaho
Posted: 02/09/12 10:23am Link  |  Quote  |  Print  |  Notify Moderator
06 Dodge 3500 CC LB Laramie 4x4 Dually 5.9 Cummins 325/610 48RE Jacobs brake Smarty Jr
GVWR 12,200 Payload 4580
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C
27' Hallett 502, 500HP
john&bet
North Vernon,in.
Posted: 02/09/12 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have a suggestion. Just cut in a new valve in the new location and leave the old one there and open all the time.
2004.5 Dodge 2500ctd Quadcab. Lariamie, 3.73, auto. pure stock
2005 Montana 2955 5er
Chevyman2006
Georgia
Posted: 02/09/12 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I had thought about that, but the scientists at FR put the present valve where the handle is located going down.
I'm afraid if I leave it open going down the road it'll get damaged. I know your recommendation was probably to open it when I get to the camp site...but I'm sure I'd forget that part and closing it when leaving.
I want to mount the new one so that it pulls to the side versus down.
mobilcastle
OH
Posted: 02/09/12 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Makes sense
