jpajax
North Carolina
This is my first MH and new to the air bags, when in storage do you air up suspenision or dump? I have a 2009 Cross Country with a FL chassis it appears to have the Neway suspension. Will be attending the Camp FL this summer but would like a heads up before then.
missscarlet9
Saskatchewan
My suggestion is to dump. The air pressure may leak over time anyway.
Livin' the dream!
Big Katuna
Deland, FL
Might as well dump; its going to leak out anyway.
My Kharma ran over my Dogma.
jpajax
North Carolina
Thanks wasn't sure. Looking forward to the FL classes and that will be our first trip in it. Anything should I really need to check besides the regular things like fluid levels and tire pressure? Thanks Jim
boogie_4wheel
SLC, Utah
I would leave them filled. Keep them at their 'normal' shape as long as possible. Of course the system will bleed out over time (maybe over a couple days, or over a couple weeks).
You don't let all the air out of the tires during storage do you? They will leak air out over time...
'05 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, 74k, 2mic fuel filter on frame, Edge Juice w/ CTS
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
'07 Honda VTX1800 Tourer
'96 Honda XR400R
Big Katuna
Deland, FL
They don't put a dump switch on tires. Completely different animal.
Blaster Man
USA
I let the air out, then extend the jacks.
"Sea Of No Cares"
Michigan
I dump the air and put jacks down when in storage.
Dave and Gail
1999 Fleetwood Discovery 37V DP
Cummins 275 HP
2001 Saturn TOAD
Flyboy320
Tappen, BC
What does the owners manual say to do?
bluwtr49
Green Valley, AZ
Dump the air and put down the jacks. Much easier on the bags and tires. Besides, as was said, the air will leak out anyway.
Side benifit, the step will be closer to the ground.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
