Johnny G1
Clearwater, British Columbia ,Canada
I must have somthing wrong with my air bags, parked end of October and have not lossed 1 pound in pressure since, must be because I did my own install and made sure there was no leaks???? Just my thoughts.
1998 34' Newmar Mountain Aire,210 Cummins Puller, 542 Allison 4 speed, BD Performance Exhaust Brake, BD Torque Convertor, Hendrickson Air suspension, 4 wheel disc brakes. 4-120 Watt 2-80 Watt Kyocera panels 8-T105s Toad 2003 VW Jetta TDI.
Cat320
Somewhere in the USA
If you don't let the air our first, your coach will be way up in the air by the time the jacks get you level. On our last trip, I forgot to let the air out first, then realize it when the coach was why higher than normal.
sp8gold
Colorado Springs, CO
Guess I'm different, when I pull into the shop building, I run the jacks down until they touch the floor and leave it. I do not dump the air.
